1 223,000 miles on running engine. Replace? Sat Aug 16, 2014 12:03 pm
stilbo
Wringing hands over whether or not to replace a 100 engine. 223,000 miles but was running decent before bike tear down. PO had all scheduled maintenance done at BMW shop since 4,000 Miles. Compression cold was 190 175 175 190. Compression at operating temp was 120 75 75 115. I think the throttle plates snapped shut on the hot test so not sure about accuracy. Found an engine for $450 shipped with 58,000 miles.
With this many miles I'd pretty much always disassemble and mic pistons and bores and replace rings if that's all it needed and rebuild head. But: the gasket set alone is $230 plus whatever rings, head, water pump costs are and then there's the possibility of having to replace pistons, valves etc. those costs could easily run $300 best case to $500 + in worse case... The injectors are probably candidates fir replacement as well. And again I have the opportunity to install a "plug and play" engine with just a throttle body clean up and clutch. For $450.
Any thoughts?
Ron S
Any thoughts?
Ron S
