1 Insulation Kit for K100 RT Sat Aug 30, 2014 10:13 pm
AJ.Valente
Well, the summer's almost over here in New England, and it's time now to release the results of an insulation test aimed to reduce fuel tank overheating on the early models.
The RT was the last of three models to be released in 1984, the others being the RS and the K100. The only plan for insulating was to add reflective strips glued to the bottom of the fuel tank, and a foam rubber sleeve on the return fuel line. As the summer of '84 wore on it became apparent this had been inadequate as many an owner reported over-heated fuel tanks.
The only change made to the RT in the '85 model year was to remove the fork boots that sealed the underside of the faring, and attach air scoops to the back of the openings. This approach had been a small improvement, but bikes continued to experience over-heated fuel tanks while operating in heavy traffic, stop-and-go urban riding, or in desert conditions.
On this board, the recommended method of eliminating fuel tank over-heating is through the addition of a fuel cooler, which circulates the fuel return line through a separate radiator attached to the main radiator. This method is the only real solution to desert riding conditions.
-continued-
-continued-
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
