1 Neutral Function Sun Aug 31, 2014 2:36 pm
KafeRacer
I am planning to use the existing gear indication display relocated in the main fuse box to power the neutral indicator on my Dakota digital instrument cluster and to allow the bike to start in neutral without pulling the clutch.
I just need to verify the pin out on the gear indicator circuit board. I think I have it mostly sorted out. Can anyone help me verify.
Pin 31 - Ground
Leerl - Provides 12+ to Neutral Bulb, and goes through -->|-- diode to the black/green wire that provides 12+ to the starter relay.
C - Yellow - White from Gear Pos Switch
B - Yellow - Black from Gear Pos Switch
A - Yellow - Blue from Gear Pos Switch
15 - Power 12+ from Green/Black wire from fuse 1.
I believe Pin 31 is ground because the ground on the Gear Position Switch is labeled as 31. Pin 15 connects to pin 6 from on the back of the instrument cluster which I read was the Green/Black +12 wire from fuse 1.
Pin 31 - Ground
Dave Evans
'Kafe Racer'
kaferacer.wordpress.com
1990 K75RT
1985 K100 Kafe Racer
