1 '86 K100 will not run Sun Feb 28, 2010 2:32 pm
jaybutter
Hi everyone,
I have done something to my bike and need some help. I replaced my failing battery and now the engine will only run at a very slow idle for a few seconds. I have done a lot of troubleshooting to no avail. Here is what it is doing. The bike was runnig well and normaly just before the change of the battery.
It will run only with no throttle applied, roughly, with no power, only below 1000 rpm, for a few seconds. If I add any throttle at all it instanlty dies. Here is a list of things I have checked.
Ground at the battery, ground wire at transmission attachment point, and ground point under the tank on frame are all good.
Symtoms are the same with the idle switch conneceted or disconnected.
Fuel pressure is 35 psi, pump runs untill engine stalls.
plugs have spark at all throttle positions.
Symtoms are the same whether I release the start button or hold it down.
Starter cuts off at about 750 rpm when holding button down.
Pulsing 12v at fuel injectors at all throttle positions.
All inputs to fuel injection computer when measured at the connector are in normal range as per the troubleshooting guide.
So I am stumped. Again, the engine dies instantly whenever the throttled is opened at all but will lope along at less that 1000 rpm for a few seconds when attempting to start with no throttle. When trying to start with no throttle the engine tries to run, add any throttle while cranking and you can hear that the engine loses that almost running sound and just cranks with no firing. There is spark however in this condition. Please help before I go nuts! Thanks very much.
I am very impressed with Berts troubleshooting guide. It is very practable and contains information that no other source has concerning the operation and repair of the K bike fuel injection and ignition system and componants!
Jay
Jay
