1Back to top Go down   Old gas/new gas Empty Old gas/new gas Sat Aug 09, 2014 3:45 pm
BooG
BooG
Mixed some old gas in a plastic jerry can with half a tank of new gas in an attempt to get rid of it, and...
1) Smoking
2) Backfires
3) Evolving engine rattle..getting worse
4) Loss of power...
I think the valves might have suffered......
any pearls of wisdom?   Old gas/new gas 177381
2Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:09 pm
BooG
BooG
Maybe the injectors have deposits....
big old backfires, like gunshots!
3Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:14 pm
Mort
Mort
How old was the "old gas"?
92 K100LT
4Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:22 pm
BooG
BooG
eerrrmmmm......2 years....ish.....
5Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:24 pm
Mort
Mort
BooG wrote:eerrrmmmm......2 years....ish.....
Ok, it is 4 year old pish... Laughing
92 K100LT
6Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:27 pm
BooG
BooG
Not more than four, but no younger than 2! Not exactly sure.
I read somewhere that the only way to dispose of old gas is to add it to existing gas, and burn it off. I would advise anyone reading this NOT to try it!!...certainly not in the case of a 1988 K75S!
7Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:30 pm
Mort
Mort
BooG wrote:Not more than four, but no younger than 2! Not exactly sure.
I use stuff like this in my chain saw, modern additives do not work well as a fuel, OK as a solvent but not worth the agro in an engine.
92 K100LT
8Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:34 pm
BooG
BooG
I guess I'll have to remove the valve/rocker cover and inspect. May need to remove the head to clean it and reset the valves. Blimey....!!! I'm kicking myself!!!
9Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:45 pm
Mort
Mort
BooG wrote:I guess I'll have to remove the valve/rocker cover and inspect. May need to remove the head to clean it and reset the valves. Blimey....!!! I'm kicking myself!!!
Seriously mate, I doubt it's that bad, drain the old stuff out of the tank and start again.
92 K100LT
10Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 6:55 pm
BooG
BooG
But....what do I do with the old gas? Back to square 1! Will have to get shot of it somehow, but council say they don't take petrol.
Is there some kind of additive that can help clean the valves?
11Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 7:02 pm
floyd
floyd
I know nothing
BUT I did watch this the other day.... (NB its not just about oil)
12Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 10:04 pm
Ghost who rides
Ghost who rides
Unlikely you would damage valves that quickly, pull the spark plugs and clean them.
Give the gas to a car driver or put it in yours if you have one.
13Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sat Aug 09, 2014 11:09 pm
You wont have damaged anything except maybe the spark plugs. Old fuel doesn't burn and will usually not even start even with fresh fuel added.  Add it to fresh tanks of fuel about 1 litre at a time to get rid of it or leave it outside on the footpath and some mug will steal it and have their car conk out on them just down the road and you can go take the piss out of them for stealing it and make them buy you a fresh can. Very Happy
14Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sun Aug 10, 2014 8:25 am
BooG
BooG
That Archoil stuff looks interesting. Have read up on it, and they have a product that may work if added to the gas. Good idea..or just drain off/clean plugs/new gas??
15Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Sun Aug 10, 2014 11:35 am
the.postman
BooG wrote:..or just drain off/clean plugs/new gas??
That's the way to go.
Put the old stuff in a can at the back of the shed and use for cleaning
1984 srx 600
1986 cbr1000f/h
16Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 11, 2014 6:58 am
BooG wrote:But....what do I do with the old gas?
Find a neighbour that you don't like and then late one night use your creative spelling talents to write something witty on their front lawn.  That is if you have more than a couple of blades of grass at the front of your house in your piece of London.
Works a treat, especially for words that children should not see.
Speaking with a mate of mine recently in the automotive industry and his comment is that all 91 Octane in Oz has a shelf life of about two weeks and is crap.  Hence I use 98 in my bikes.
17Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 11, 2014 7:18 am
k-rider
k-rider
I have had the old fuel trouble a couple of times after winter storage (some day i will learn ) .
the bike simply would not start unless i used the diesel start , i then aplied  the lead substitude i use during the summer , and after draining the fuel rail ,and a few more tries ,bingo  cheers it started .
worked on the lawn mower too.
k-rider
18Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 11, 2014 6:05 pm
floyd
floyd
Get some of this K-Rider Wink
Old gas/new gas 563_sm
19Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 25, 2014 11:01 am
BooG
BooG
I sometimes wish I was Australian, just so I can buy products like that!!! Nice!
Anyway.....old gas drained....new gas in just now....starts up  but running ruff!! Smoke out back...uneven idle...and knocking still. Should I keep running it (as the remainder old gas passes through the pipes and is burnt off) , or what else is a good idea? Old gas/new gas 8157
20Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 25, 2014 11:50 am
BooG
BooG
Looks like I am only firing on one or two cylinders at mo. That would explain the smoke and occasional backfire. Would that old gas block up the injectors? Is that the most likely culprit?
21Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 25, 2014 8:40 pm
I would be cleaning the injectors and new plugs if you haven't already done it. Even cleaning the outside of the coils can be a help, I have seen coils with tracks burned across them come back to life after a good clean.
22Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Mon Aug 25, 2014 8:57 pm
BooG wrote:Looks like I am only firing on one or two cylinders at mo. That would explain the smoke and occasional backfire. Would that old gas block up the injectors? Is that the most likely culprit?
Any consistency in which two cylinders are not firing? Just after you try starting up feel the headers and see which ones are cold. If 1 and 4 or 2 and 3 as pairs are cold then you have a coil issue, but maybe a connection and not the coil itself.
23Back to top Go down   Old gas/new gas Empty Re: Old gas/new gas Tue Aug 26, 2014 2:35 pm
BooG
BooG
Very Happy Cleaned and gapped the plugs. Cleaned injectors...new gas...sorted!
Thanks for all the helps and advice!
