1Back to top Go down   Fuel tank cap - rekeying and repair Empty Fuel tank cap - rekeying and repair Sun Sep 16, 2012 8:08 pm
My temporary solution was so effective it took 6 months to get around to this..Having assembled the bits I finally got around to it today.
Most tank locks fail when the little nibs on the lock barrell get corroded and break down. The corroded barrell then chews the holes in the plastic receiver cup leading to the barrell just spinning without activating the latch. The pictures below show the old versus the new barrell and the new plastic cup.
Fuel tank cap - rekeying and repair Img_0910
Fuel tank cap - rekeying and repair Img_0911RE
Ok so getting at the parts....
with the tank open and the opening covered in case of dropped parts ....(if you have to force or drill the old lock out don't worry things cannot get through to the tank with the cap closed.) remove the 3 screws and carefully withdraw the plastic cover..
Fuel tank cap - rekeying and repair Img_0912
there are two springs in there, one like a biro spring which can fly so take care.
Next remove the barrel it is held in by the last tang (you need the key in the lock) push the tang in with a flat blade screwdriver and remove the barrell.
I did get keys with the replacement lock from motobins but I wanted it on the original key. The simple way to rekey it is to stick in your ignition key and file off any tangs that stick proud of the barrel. Be careful not to file the last one. A bench grinder makes this super easy but the tangs are brass and soft so it's a quick job.
Once your happy, press in the last tang (with the key in the lock) and insert it in the cap. When it's properly seated it should look like this...
Fuel tank cap - rekeying and repair Img_0913
next you need to replace the retrun spring in the cover, then the receiver cup, the latch plate and the biro like push spring that keeps the latch pushed out. It should look like this .....
Fuel tank cap - rekeying and repair Img_0914
There is a spring behind the cup that I omitted to photograph but where it goes (in grooves) is quite apparent.
At this stage you need to screw it all back together and test carefully. I found that testing it with just hand pressure instead of the screws didn't work.
There is surprisingly little movement in the latch but make doubly sure you are happy with everything before closing the cap.
I must say a big thanks to MotoSmith who sent me the plastic cup from California. I don't know the part number for that. Maybe one of the members who is good at finding them will post it up.
88KE
Fuel tank cap - rekeying and repair Ir-log1188....May contain nuts!Fuel tank cap - rekeying and repair Ir-log11
K75RTP - 1994
88KE wrote:I must say a big thanks to MotoSmith who sent me the plastic cup from California. I don't know the part number for that. Maybe one of the members who is good at finding them will post it up.
It`not sold as a single part, you have to buy a complete filler cap.
That's a shame because the complete cap is not cheap and the job is straightforward.
See your friendly wreckers I guess!
K75RTP - 1994
good process and descriptions 88
thanks from many of us ..
Another fix for the problem with the plastic cup is to be found here.
Very Happy Very Happy
This would be a minor issue with the new bike. It has an 11 gallons auxiliary fuel cell in the sidecar and I would just have to turn ON the transfer pump.
Sorry, the rig won't be delivered for another week but I am already bragging about it.
CF
Fuel tank cap - rekeying and repair Frog15Fuel tank cap - rekeying and repair Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
Good one 88 & motosmith.This forum never ceases to amaze.
When I had my cap apart, a bit of grease on the sliding parts improved the action no end.
An extra 11 gallons, you lucky %$^&* CF! (Can't find an emotion for jealous.)
Razz
I am so excited about getting the new bike.
I bought it without seeing it as I totally trust my fellows BMW riders.
This is what I wanted and after waiting patiently for almost 10 years, I found it.
I have to admit that the owner of the rig registered on this forum about a month ago.
During a private conversation, he expressed his intention of selling his bike. I told him that I was very interested but he didn`t think that I was serious.
After multiple Emails, we learned to know a bit about each others, and even if he`s sad about selling the rig, he`s happy knowing that his baby will be in good hands.
CF
Shep
Shep
I know this is an old post but it is the closest one to discuss my current issue with reassembling a gas cap.
I also watched Chris Harris (You-tube) and it seems he tensioned the small spring under the receiver cup with the receiver cup  before he replaced the latch and spring. I have had difficulty doing what Chris Harris did (need three or forur hands).
I then looked at page two of Inge's post and will go back to that orientation. However the key and latch did not have the same snap when I did it that way. My other K bike has an extremely positive spring return when the key and latch are operated.
S
Shep
Shep
Okay so I figured out how to get the positive spring return when you turn the key to open the latch and I didn't need three hands.
My next question is regarding the plastic nose piece:
Fuel tank cap - rekeying and repair Z
What is its function? When I tried to pop it on an old fuel cap I broke one of the tangs and it was just empty inside.
On the fuel cap I just put back together there appears to be something whitish inside but I don't want to try to pop it open when there is no reason to do so.
S
