1Back to top Go down   K75S misfiring when cold Empty K75S misfiring when cold Sun 17 Aug 2014, 06:54
john dorman
john dorman
I have a 93 K75S that is misfiring when cold,once I coax it over 3th revs it runs better. Have checked the fuel & air filters ( cleaned out the mouse nest in airbox ) but still runs poorly  when cold . Any suggestions on what to check would be appreciated. JD
2Back to top Go down   K75S misfiring when cold Empty Re: K75S misfiring when cold Sun 17 Aug 2014, 07:02
Make sure all the electrical connections on the ignition are good, pull the plug caps and check the little bobbins are on the top of the plugs and that the leads are connecting, white powdery stuff is a give away to a bad connection on the high voltage side. Even replace the plugs.
3Back to top Go down   K75S misfiring when cold Empty Re: K75S misfiring when cold Sun 17 Aug 2014, 08:51
aye +1 on that
4Back to top Go down   K75S misfiring when cold Empty K75S misfiring Thu 21 Aug 2014, 06:10
john dorman
john dorman
Put a set of new plugs in and she's running like new!
