1 Classic Sport Touring '85 K100RT Wed 16 Apr 2014, 11:08
AJ.Valente
With the lines of a classical sports car--it's the '85 K100 RT. The RT model was the top-of-the-line early K-bike, but after riding this bike for 2 years in "touring" configuration I finally realized it might go faster and handle better by simply lowering the handlebars. This configuration is more comfortable (less noisy) at speed, and handling is much improved. Who knew that lowered handlebars are what the designers intended all along (see post on: K100RT Egronomics).
Now with the advantage of modern tires and and a few bolt-on modifications this bike is ready to do what it was born to do, sport touring! Oh ya, and did I mention--it's red!
Figure 1 above; (left) RT handlebars when lowered down look very similar to RS handlebars (right). The clean rear deck of the early '85 RT merges seamlessly with Corbin gunfighter seat. The '85 also has a center stand upgrade to K1100 style, and note the tri-spoke rims (rare) from '93 K75S.
The RT is very similar to the RS in many respects, the only real difference being faring design and rider protection. Otherwise, the engine, brakes, and suspension are all the same, and the two bikes weigh within 10 pounds of each other. The RT does have a lower geared rear end that makes it slightly quicker in the 0-60, and provides more torque for passing, etc. The '85 and earlier K bikes also have 16-tooth splines that are less susceptible to wear.
Figure 2 above; Monolever rear end w/32-11 gears for quicker acceleration. Aluminum parts unpainted in RT style. Footplates from '86 K100.
continued . . .
continued . . .
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
