1Back to top Go down   Newbie from New Zealand Empty Newbie from New Zealand Thu Aug 28, 2014 6:25 am
madmal
madmal
Hi all
I have acquired a 88 RS that is in a fairly bad state at the moment. Rescued if from a shed where it has been sitting for the last few years. The poor thing has lost all of its fairings and has a dinged front rim along with slightly bent front forks and other minor bits missing
Only took me about 2 minutes to get the old girl fired up and running, so at least it runs.
Have got a K100 solo seat coming so looking to go naked instead of trying to put it back to original.
Joined up here to tap into the wealth of knowledge and I'm sure the banter as in other forums.
Its my 1st BMW and my 1st project bike so its going to be a learning curve.
2Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Thu Aug 28, 2014 6:40 am
Welcome to the forum.
Now first things first. Don't fire it up! Check out on the home page what to do if you have just bought a K. Reason being you don't want to clog up injectors etc etc. Clan fuel tank and change fuel filter before you run it again, clean the old fuel out of the fuel lines. You don't want the fuel filter blocked and you don't want the stuff blocking the injectors. Ideally you should change the fuel lines as they perish with age and can crack- they are pressurised and if they crack will spray fuel and you don't want that. They are cheap and easy to do.
Front rim will be easy to come by, so will forks. If you replace forks some put a K1100 front end on to the K100 but you should pick up the K100 forks easily. New tyres a must due to age hardening.
In a shed presumably means in the dry under cover so she may not be bad.
I guess you will enjoy the K and the banter too.
3Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Thu Aug 28, 2014 6:59 am
welcome aboard mal
have fun with getting the old girl on the road
yes, drain all the fuel and do the clean up before going too far
4Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Thu Aug 28, 2014 1:34 pm
Be made
Be made
Hiya. hows things in the capital. welcome to the forum man, this place rocks. good luck with the rebuild. Unfaired K's is something we will have in common
Regards
Keith
Waikato
5Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Sun Sep 14, 2014 7:29 am
mawhera
mawhera
Welcome madmal, great stuff, nice to meet if you are on a run out kapiti coast. mines on Trademe at mo, noy worried if I keep it. Re fuel filter inside tank, ryco do a good one $24.
Rick
Newbie from New Zealand Nz_log10
Rick
K IWI land
New Zealand
6Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Sun Sep 14, 2014 7:37 am
Welcome madmal.
When I saw your avatar, I thought "Well, I suppose he's got to start somewhere!"
7Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Mon Sep 15, 2014 5:55 am
Be made
Be made
blaKey wrote:Welcome madmal.
Newbie from New Zealand 44271 Newbie from New Zealand 44271 Newbie from New Zealand 44271 Newbie from New Zealand 44271 Newbie from New Zealand 44271
8Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Mon Sep 15, 2014 7:41 pm
Do you think he may be taking the minimalist thing a bit far Blakey
9Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Wed Sep 17, 2014 4:24 am
madmal
madmal
Well you are sort of correct!
The wheel in the picture is a replacement for the bent one that came on the bike, and it actually arrived in the workshop before the rest did.
10Back to top Go down   Newbie from New Zealand Empty Re: Newbie from New Zealand Thu Sep 18, 2014 7:15 am
"Do you think he may be taking the minimalist thing a bit far Blakey"
Definitely from the "less is more" school of thinking..
Good to have you along madmal!
