1 Quick fix, circuit breaker, save your brick from burning. Sat Jul 20, 2019 2:52 am
daveyson
Here is an option to consider if you're interested in reducing the possibility of damage to your brick from a short circuit.
1- Remove the fuel injection relay wire from the positive of the battery (the thinnest of the three)
2- Snip the red ignition switch wire at the starter relay (the thinner of the two) but leave enough length to add a connector in case you want to reverse the procedure.
3- Connect these two wires to the auxiliary terminal of a 15 Amp circuit breaker.
4- Run a new wire of good diameter from the battery positive to the circuit breaker battery terminal.
5- Bolt the circuit breaker where you like, on top of the coil cover is a good spot, I think. Then tidy up the wires.
A "B-curve" DC circuit breaker is the best option.
Last edited by daveyson on Sun Feb 16, 2020 11:36 pm; edited 4 times in total (Reason for editing : added photo.)
11/1985 BMW K100RT (late model) Vin. 0090567
~120,000 km
