1Back to top Go down   K1100LT rack Empty K1100LT rack Thu Mar 20 2014, 07:53
Mike101
Mike101
So i bought one hoping to put it onto my LT as i want a bigger top box.
It's not a straight fit...but i guessed that before i bought it.
The rear passanger handles have to come off.
The front mounting points are OK but recessed in a long way.  If i use them as they are and with the space on the new rack i will either snap the new frame or break the bike plastics.
The rear mounting points are in teh right location but i'll need to cut the number plate holder back to get to the bolts...maybe a spacer needed here.
What i didn't know is the rack is not flat...the rear bar is set higher than the rest making mounting a flat plate hard.
It's a big faff getting it done..all i want is a bigger top box.
Mike
K100LT 1987 Gold and not Beige
XT660Z Tenere
2Back to top Go down   K1100LT rack Empty Re: K1100LT rack Thu Mar 20 2014, 08:44
Can you pop up a photo?
3Back to top Go down   K1100LT rack Empty Re: K1100LT rack Thu Mar 20 2014, 11:12
It's a own kit to fit the 35L topbox rack to the 2V models....single parts is NLA.
K1100LT rack Barer10
4Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 06:44
Looking at the K1100 fische, it's meant to go with the standard pannier racks. I don't see any spacers.
The lip at the back is a part of the locking mechanism for the large BMW top box.
K1100LT rack B0001124
5Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 09:51
MikeP
MikeP
RobinW wrote:Looking at the K1100 fische, it's meant to go with the standard pannier racks. I don't see any spacers.
My project ex-K1100LT came with panniers and the 35 litre top-box. I haven't got around to doing anything with it apart from strip it all off back in September.
You do seem to be correct Robin, the 35 litre rack mounts on the upper mountings of the Z-rails - if the bike has panniers.
From Inge's post, it looks as though there is a spacer bar for mounting the rack if no panniers and Z-frames are present.
Apart from that, I cannot imagine why the rear mudguard or the number plate mounting section would need to be modified.
1992 K1
6Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 10:57
Mike101
Mike101
I can't get pics on here today but let me explain in terms of the earlier picture.
I have pannier rails to fit the rear rack onto.
Bolt number 3 on the pic holds the pannier z rail onto the frame by the number plate holder/ mudguard thing.  The problem is that the rear mudguard thing sits over this bolt covering it completly.  i will ahve to cut the rear mudguard to expose the bolt so i can fit the rack to it.
Bolt number 2 holds the frong of the rack in place.  The plastic trim/panel under the rear of the seat sticks out so far that i cannot do up this bolt.  I will either bend the rack fail and snap it or break the bike trim thing.
With some spacers it will fit but it's not a straight on thing.
Mike
XT660Z Tenere
7Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:16
K1100LT rack Tail
The yellow circles are the mount points. Ignore what I have in them.
I can't see how the rear one interferes with the number plate.
8Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:23
The rear mudguard is different on 2V's than the 4V's.
Also the frame brackets is moved ~20mm out from the center
of the frame on each side on the 4V's.....caused by the paralever.
9Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:28
He's got a K1100, or at least I thought it was.
Maybe it isn't ?
10Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:32
In -87 the production of the K11's wasn't started yet.
11Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:40
You are right again, he shows a K100LT in his sig not a K1100LT
No wonder everything is arse about.
12Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:47
Mike101
Mike101
I've got an 87 K100LT...
The bolt holes do line up so it should fit but my bike just looks a bit wider than the fram is designed to fit.
I'll have a play this weekend and see where i get.
Mike
XT660Z Tenere
13Back to top Go down   K1100LT rack Empty Re: K1100LT rack Fri Mar 21 2014, 11:53
Parts #6 in reply #3 is the spacers that's needed......could give you some ideas.
14Back to top Go down   K1100LT rack Empty Re: K1100LT rack Wed Aug 13 2014, 16:44
floyd
floyd
So Inge, just to confirm...
Any rack designed to fit using the Z frame mouting holes will be wider on a k1100 then a k100 as the k1100 is wider at the point due to the paralever?
Correct? So in theory at least a rack for an 1100 will fit a 100 with spacers?
15Back to top Go down   K1100LT rack Empty Re: K1100LT rack Wed Aug 13 2014, 17:09
