1Back to top Go down   Radiator cap Empty Radiator cap Wed Jul 23, 2014 3:53 pm
I've had some odd things happening with the water levels in the coolant bottle lately, which I think are caused by the radiator cap playing silly wotsits.
As the cap has been on the bike for 28 years, I thought I'd buy a new one and, to my surprise, the new cap is quite different from the old one. The flat rubber seal is now fitted in a recess so that it can't spread outwards. You'll see from my pic that the old flat washer, no more than 5 years old, has already 'spread', compared to the new washer, by 3mm on the diameter making it a loose fit in the cap.
For reference a new seal is 35mm OD x 24.5mm ID.
Radiator cap Sam_0818
I wonder when the design changed?
2Back to top Go down   Radiator cap Empty Re: Radiator cap Wed Jul 23, 2014 10:26 pm
japuentes
japuentes
Hi there, I noticed the same when changed the cap last december, but the bike has been runing with no issues.
Think the new strain over the valves inproves the design, cause must of mine troubles with the old cap were due to particles inserted in the valves.
Best regards
JAP
Radiator cap 2854237993 1988 K100RS SE/ABS
