1Back to top Go down   k1100 sidecar mounting query Empty k1100 sidecar mounting query Sun Jul 20, 2014 8:00 am
ausbrick
ausbrick
k1100 sidecar mounting query Bmw-2stars
k1100 sidecar mounting query Online12
Number of posts: 56
Country: Australia
city or state: Melbourne Mornington
Hi everyone I have recently picked up a sidecar and I'm looking to fit it to my k1100 .Wondering if anyone has any plans or good photos showing the subframe required and best points to attach it on the frame of the bike. At the moment I have  no mounts on the chair it's a basic square chassis with torsion type suspension and a 10" mini wheel . So I will have to fabricate the subframe and all connecting bars . Does anybody know of a good adjustable type of mount system  available in AUS  or a source for some sort of turnbuckle that may suit , sure I saw someone post something about the adjustable rods they used somewhere a while ago .  will post some pics of chair soon . Cheers AB
2Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Sun Jul 20, 2014 8:32 am
Aus , this may be what you were looking for , hope it helps.
look forward to seeing pics of your new chair.
k1100 sidecar mounting query 10_x_110
3Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Sun Jul 20, 2014 8:48 am
Front top bolts to top crash  bar mounts.
k1100 sidecar mounting query Img_0727
Rear top
k1100 sidecar mounting query Img_0728
I will send photos of the cradle that conects to front top and goes around and under the motor and bolts to gear box in place of rear stand.
It's at the sand blaster I will have it back tomorrow.
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
4Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Sun Jul 20, 2014 9:58 pm
The cradel
I think Al said this is a HRD subframe
k1100 sidecar mounting query Img_0812
Conecting bars
k1100 sidecar mounting query Img_0813
K100 RS
R1200GS
650 Vstrom
5Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Tue Jul 22, 2014 5:27 am
Waz wrote:The cradel
Conecting bars
Yep, sure is.  The two front tabs bolt to that plate shown in your other pic.
'93 K1100LT
k1100 sidecar mounting query K-dogs10
6Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Tue Jul 22, 2014 5:20 pm
I like it. That's a neat sub-frame Waz. k1100 sidecar mounting query 112350
7Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Tue Jul 22, 2014 8:26 pm
Thanks Paul
I am hoping I can fit he LT fairing over and around it without too much cutting.
K100 RS
R1200GS
650 Vstrom
8Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Wed Jul 23, 2014 2:06 am
Waz wrote:Thanks Paul
I'll try to dig through my photos to see if there is a photo with that detail.  From memory there is a little trimming along the lower edge of the radiator panel, a small piece cut away at the lower edge for the mount to stick through and if you are fitting a steering damper there is a chunk cut out of the front edge and replaced with a fibreglassed in half-tube to give steering damper clearance.
Ron (HRD) eventually just made a mould of the radiator panel with all the mods included and just replaced the panel instead of modding them to save time.  Highway Sidecars may have that mould.
'93 K1100LT
9Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Wed Jul 23, 2014 5:25 am
Thanks Al
I will check with highway, I think I have to have a steering damper dont' I?
K100 RS
R1200GS
650 Vstrom
10Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Wed Jul 23, 2014 7:57 am
you're right there Al . the radiator shroud has some mods for the linkage to poke out the side, with additional moulding for a damper rod.
Aus did you get a chance to eye off any outfits at Tottenham ?
Steve Treloar's blue RT outfit has exactly the same subframe as Waz's.  fitted with a John Marshall 1 1/2 seater chair ( DJP look a like) and 10' mini wheel.
from the looks of it , a very simple design to work with , and would suit the DJP very easily.
11Back to top Go down   k1100 sidecar mounting query Empty Re: k1100 sidecar mounting query Wed Jul 23, 2014 9:55 am
groverK wrote:you're right there Al . the radiator shroud has some mods for the linkage to poke out the side, with additional moulding for a damper rod.
Steve Treloars blue outfit was the one I was referring too.  The subframe is from Mick Mathesons K100RT outfit, I got the leading link.  He already had the John Marshall sidecar but fitted to an R100RT before he bought the K.
'93 K1100LT
