1 no Start-k100 Sun May 11, 2014 11:04 pm
maibsassy
The bike originally would not start. If I cranked it for a long period sometimes I could get it running. I put in new spark plugs, new injectors. I have a couple of FI computers and a spare Ignition module that I have tried to no avail. I followed your testing procedure in CrazyFrog's article(test at the pins) with these modules and found nothing wrong with the voltages. I thought It could be out of time, and put in a new hall effect sensor, again nothing. ( I used your procedure for testing with a diode- tested at the connector). When I try to start the bike, it doesn't seem to start up at a fast idle even with the choke set to fast. The spark plugs and injectors seem to be working - with the injectors I tested them with a noid light and with the spark plugs I used tester lights. I tested the FI relay and it seemed to be OK. The spark plugs and injectors seem to be working which would indicate the FI relay is working. I did replace the FI relay with another one. Also, I cleaned the throttle bodies.
Everything I have tried to get the bike started has not worked.
I have been trying to get the bike started all winter and have run out of options to try. This is something simple that I am overlooking, or I need a test procedure to test a "no start".
Any help would be appreciated!
