1 Fettling my K100 following conversion to K1100 throttle bodies Wed Jul 23, 2014 9:02 am
Fentible
I converted my standard naked 84 K100 to k1100 throttle bodies and using the standard k100 TPS, I am also using an uprated injector that has the same flow rate as the original injectors but uses a multipoint flow head that allegedly improves atomisation and hence the burn rate. Everything else is standard K100.
The bike starts easily and needs choke when cold. It settles into a reasonably steady 1000rpm tick-over however there is a tendency to regularly hunt between 950 - 1050. My nose tells me it smells rich and when I remove the plugs sure enough they are black. I can't tell if its my imagination but there also seems to be a momentary lag when revving up from tick-over. It may simply be a case of 'they all do that' but it isn't noticeable when revving up from 2000rpm.
I have balanced the TB's and I also can't detect any vacuum leaks, but I thought if anything that would cause lean running. I know you can adjust the idle mix on the MAF, clockwise or counter to lean off?? I don't have a sniffer so any adjustments would be seat of the pants.
Also when first turning on the ignition, should all the warning lamps light up?? My temp lamp doesn't.
I must stress I haven't had the bike on the road yet as its not currently roadworthy. So all running is on the bench.
Ideas or suggestions gratefully received
