Go to page : 1, 2  Next
1Back to top Go down   Permanent side stand puck Empty Permanent side stand puck Sun Apr 01, 2012 4:31 pm
MT350Explorer
MT350Explorer
Hi Guys,
The mainstand is killing my back - which is a bit knackered anyway. Has anyone found a permanent sidestand puck solution to give a bit more confidence the 'K' will stay upright? I reckon my sidestand is a bit worn at the pivot but I've done all I can to limit movement there.
Here's an example on another Beemer forum. Anyone tried something similar?
http://www.ukgser.com/forums/showthread.php?t=111334
Best
Dave
2Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 4:53 pm
Here's mine Dave.
Permanent side stand puck Ssl10819
It's a block of plastic fixed to the base of the stand with two counterbored socket screws.
Cheers,
3Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 4:57 pm
MT350Explorer
MT350Explorer
Hi Paul,
That looks good. Any more details please? What exactly is a counter bored screw (forgive my ignorance).
As an aside I was hoping you'd be around - I see there are no fewer than TWO K100 outfits for sale on Ebay. If I had the cash I would be very tempted indeed.
Best
Dave
4Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 5:03 pm
hi dave ...yes i had done a similar thing to paul ...but using a bit of cheese cutting board (softish plasic ) and it worked well .
the plastic was about about 75mm x 60mm x 10 mm thick and fixed with 2 x 3mm stainless screws through the metal foot with nylock nuts .
it held the bike up more verticle and griped well ...previously the lean angle was a bit extreem ....giggle
since changing to the newer centre and sidestand the need has disapeared as the sidestand is much better
but you might be able to see it faintly in this pic
Permanent side stand puck Pics_026
Permanent side stand puck Pictur70
5Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 5:12 pm
MT350Explorer
MT350Explorer
Thanks Charlie Very Happy
I was racking my brains for what sort of plastic might work - and a cutting/cheese board sounds good.
Will give it a go - increasing the size a bit over the standard foot would also inspire confidence but I guess will be limited by contact with the exhaust.
Thinking cap on...!
Best
Dave
6Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 5:16 pm
yes defininatly .... just be aware that you may have to look at the design a bit as it might interfere with the centre stand arm ...and of corse the muffler .
7Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 5:35 pm
If I remember correct you got a 16V? Which have the same stands as the K11.
I did this mod on my K11 some years ago, added a 8mm thick piece of rubber.
I was very pleased with the result, it did follow the shape of the genuine foot exatly all around.
I did want a clean look...no screws or rivets....so I did use a strong glue.
And let it cure overnight with the bike resting on the sidestand..............
just to find out the next day that it wasn`t space enough for this with the sidestand folded up, it was hitting the lever on the centerstand.
8Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 5:41 pm
MT350Explorer
MT350Explorer
Thanks Inge, yes it's a 16 valve.
As you suggest I'll certainly need to check what's feasible without fouling the exhaust or mainstand!
Glue is an attractive idea. I'm a great believer in Araldite Very Happy
I'll report back when I'm finished
Best
Dave
9Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sun Apr 01, 2012 6:47 pm
Hi Dave,
The counterbore is just to recess the head of the screw. I tapped M6 into the foot of the stand.
Rubber might be a good option as Inge suggests, then it should be easy to trim if it catches on anything.
Yes, I've seen the two outfits on e-bay and there have been some good looking K's on offer recently.
Cheers,
10Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 6:38 am
Yes, I remember now, I had to file a chamfer on the edge to clear the centre stand lever. This was, of course, with the early stand.
Permanent side stand puck Ssl10820
11Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 6:52 am
Take care with this centerstand, as it is the old model which is prone to break.
12Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 7:03 am
captaink
captaink
Glad i read this, mine needs this must modification too!! I think the wife will be losing a bit of her chopping board this afternoon Permanent side stand puck 652573
13Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 7:15 am
Yes Inge, I keep an eye on the stand because the bike's original stand rotted through from the inside. This stand is the one from the outfit which only had two year's use as a solo, so at the moment it is still sound (fingers crossed). When I fitted it I filled the tubes with waxoil.
Cheers,
14Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 7:36 am
The reinforcement at the foot lever was changed after the model you now got,
it was left open in the ends.
But the newer model also breaks, don`t ask how I know....
15Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 8:20 am
MT350Explorer
MT350Explorer
captaink wrote:Glad i read this, mine needs this must modification too!! I think the wife will be loosing a bit of her chopping board this afternoon Permanent side stand puck 652573
Nice one Captain! Like the Avatar, you can't beat a bit of Trek. Very Happy
I was thinking of where I could get a block of hard rubber that would be a bit spofter than a plastic board - something like the material that makes the rubber bungs on the end of walking sticks!
Best
Dave
16Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 11:45 am
MT350Explorer wrote:I was thinking of where I could get a block of hard rubber that would be a bit spofter than a plastic board - something like the material that makes the rubber bungs on the end of walking sticks!
Best
Dave
Dave - go yo your local scrapper and get and old axle bump stop off a car or 4x4. I recon that would be ideal hard rubber and comes in round square and rectangular profiles, more than big enough to stand a bit of trimming.
17Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 1:26 pm
MT350Explorer
MT350Explorer
Nice idea 88, thanks! Very Happy Very Happy
Now I can stop eyeing the knobblies on the MT350 while clutching a hacksaw in my sweaty mit....
18Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon Apr 02, 2012 3:22 pm
captaink
captaink
I've just used a hard plastic, it's old use was an insert for bashing in those steel spikes for fence posts, filed it to a rough shape and angled so it clears the stand. Works ok in garage. . . if it lasts the week i'll post the pic's cheers
1989 k 100rs
19Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Wed Apr 11, 2012 8:20 am
MT350Explorer
MT350Explorer
Hi Guys
Bought a jewellers dapping block for a fiver on Ebay. It's 1 inch thick rubber.
Permanent side stand puck Stand110
Cut a chunk out of it and then cut a bit more depth so the foot is a bit countersunk in the rubber. Just glued on for the moment with a couple of extra bits of rubber glued at right angles.
Permanent side stand puck Stand210
Bike angle is much less alarming and seems to clear the exhuast and mainstand. If the glue doesn't stand the test of time I'll look to bolt it to the stand but would rather leave that unmolested if I can.
Best
Dave
1991 K100 RS 16 valve
20Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Wed Apr 11, 2012 8:24 am
nice one dave ...
21Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Thu Apr 12, 2012 10:30 am
MT350Explorer
MT350Explorer
Cheers Charlie,
I'd like to get some very thin metal right angle clips that could be screwed in to the rubber and apply donward pressrue on to the metal foot. Think this would work well - kinda like the clips on a 'clip frame' picture frame. At the moment haven't found anything suitable but I'm sure soemthing will show itself sonner or later....
Hope the damaged arm heals up soon
Best
Dave
22Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Thu Apr 12, 2012 10:59 am
Good thinking on the Dapping block Dave. That's good frim stuff.
If the glue doesn't hold try some black TEC7 it's got pretty amazing bonding capabilities. Better still try to find some builder or mechanic near you who has some open. Comes in a mastic/silicone sized tube - bot too pricey but a lot to open for a small job.
Permanent side stand puck Ir-log1188....May contain nuts!Permanent side stand puck Ir-log11
K75RTP - 1994
23Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Thu Apr 12, 2012 1:10 pm
MT350Explorer
MT350Explorer
Hi 88,
Thanks, seems to do the trick - no scrapywards within spitting distance and Ebay came up trumps! Very Happy
TEC 7 stuff looks good - I've used Araldite which is good but not flexible so I don't expect it to last forever.
Best
Dave
24Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Sat May 05, 2012 1:57 pm
BIG D
BIG D
Cool
Fantastic job Dave, you made me chuckle with eyeing up the MT nobblies priceless that one mate.
BIG D
25Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 07, 2012 11:09 am
GB777
GB777
I had the K11 side/centrestand fitted to my old K100. I then modified the side stand by straightening the bend in it out a bit. I did something else to it but I can't remember now as that was years ago, all I can remember was it was a lot of mucking around that I didn't want to do again.. but it worked.
Permanent side stand puck K100sfront1003
On my K11 I fitted an Ice Hockey Puk, it was a lot easier to fit and being a dense rubber I was able to secure it to the side stand by screwing self tappers through the plate on the side stand into the Puk. It also grips the ground well also. I made a timber one first and shaped it so that it would not hit on the centre stand or muffler. This was a slightly slow process taking it on and off all the time, but when it was finally finished and cleared everything, I used it as the template to shape the Puk. The Puk was exactly the right thickness.
Permanent side stand puck SideStandPuck
Permanent side stand puck 8oclockview
Permanent side stand puck Foldedrearview
Permanent side stand puck K11RS003
I must admit that the process of shaping it was made a lot easier by a stand I made up for the rear wheel to fit into, this supports the bike in an upright position so no centre stand or side stand is needed. My version of a Racing Stand.
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
26Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 07, 2012 2:22 pm
nice job !!
27Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 07, 2012 2:55 pm
MT350Explorer
MT350Explorer
Yes very smart!
28Back to top Go down   Permanent side stand puck Empty How it's called in German? Mon May 14, 2012 7:02 am
ffbikersa
ffbikersa
Anyone knows what's the German term for "Permanent side stand puck"? I mail order most of my parts from Germany, or look for them at www.ebay.de, so must know what to search for...
Tarik-with-a-leaning-K-100-LT
29Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 7:07 am
ff you found the exact thread i was looking for ....
that "puck" that gb777 made is just a good thing to have
30Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 7:23 am
Das Seitenständerpuck. ( Der Ständer is the centrestand...) You can use the word Permanent in German....or dauerhaft.
Thus: Guten Tag, ich suche ein permanentes ( dauerhaftes) Seitenständerpuck für mein Motorrad, BMW K100 Baujahr...( insert exact model and year)
Aren't you glad you asked.......?
31Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 7:26 am
seems that german has an exact definition of almost anything seani ...good work mate !!
32Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 7:31 am
Doh! I just did a search for seitenständer on ebay.de and got more than 9,000 results....good luck with that one!!
33Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 7:36 am
Narrowed it down to this:
http://www.ebay.de/sch/i.html?_nkw=BMW+K100+seitenstaender&_sacat=131090&_dmpt=Motorrad_Kraftradteile&_odkw=seitenstaender&_osacat=131090&_trksid=p3286.c0.m270.l1313
There are two or 3 complete stands...but no pucks. Seems they don't give a....oh. sorry.
34Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 7:46 am
Try bigumpuckensidestandum
35Back to top Go down   Permanent side stand puck Empty Narrow it a bit... Mon May 14, 2012 7:48 am
ffbikersa
ffbikersa
Saxon7 wrote:Doh! I just did a search for seitenständer on ebay.de and got more than 9,000 results....good luck with that one!!
Well if you narrow the search a bit to "Seitenständer BMW", there are just 252 hits. With that a man can live Cool And there are "Big Foot Seitenständer Unterlage" but only for parking on the soft ground. Also "Wunderlich Seitenständer Auflagenvergrößerung", but only for K 1200 LT. Can THAT fit K 100 LT's foot???
As I said at another place, maybe the easiest way is simply to weld a piece of thick steel plate to my bike's foot...
36Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 8:41 am
I would be inclined not to weld a thick bit onto the foot as it could cause it to bounce down when you hit a few bumps but a thick piece of hard wood would do the job just as well, there is enough room for two small bolts.
37Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 10:56 am
ffbikersa
ffbikersa
Rick G wrote:I would be inclined not to weld a thick bit onto the foot as it could cause it to bounce down when you hit a few bumps but a thick piece of hard wood would do the job just as well, there is enough room for two small bolts.
Well such a piece of metal isn't too big, think the sidestand springs would still hold it. I am affraid wood would not make this "permanent side stand puck" permanent enough, and the same applies to plastic.
38Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 11:44 am
nino
Well such a piece of metal isn't too big, think the sidestand springs would still hold it. I am afraid wood would not make this "permanent side stand puck" permanent enough, and the same applies to plastic.
Maybe a thick piece of aluminium will be light enough and safe
39Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 8:43 pm
japuentes
japuentes
I´ve been thinking about the side stand modification, and the rubber extension is the one I prefer, but the fixing and deformation problems were troubling me. Glues and fasteners are not good solution to the shear stress at the side stand´foot plate when you use a rubber extension, also the rubber deformation was too much, so I came upon with this solution
Permanent side stand puck P5020393
Now the steel wall will bear the stress and the rubber deformation would be acceptable. The rubber can be instaled with contact cement
This is the stand with the rubber instaled, The insert protrudes about 3mm
Permanent side stand puck P5140410
Now the bike´s inclination is more pleasant and not as scary as before
Permanent side stand puck P5140418
Permanent side stand puck P5140419
Best regards
JAP
40Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Mon May 14, 2012 9:10 pm
There are many commercially produced sidestand footprint extenders available. Or one can fabricate a type like this using hard plastic shaped to clear the centrestand or exhaust and riveted in place:
Permanent side stand puck Sidest10
Or purchase a version which is shaped for specific stands, tapped and threaded like this:
Permanent side stand puck Sidest11
41Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Tue May 15, 2012 7:25 am
Good Idea on the sidestand foot JAP. The bike looks greatPermanent side stand puck 112350
88KE
K75RTP - 1994
42Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Tue May 15, 2012 9:00 am
GB777
GB777
The Puck I have fitted is held on by two Self Tapping Screws and it's been that way without any signs of being torn off for about 4 years. The Puck is a very hard rubber that needed to be pre-drilled before the self tappers were screwed in.
Permanent side stand puck IMG_0663
Gary
43Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Tue May 15, 2012 4:12 pm
nino
I did the puck with two self taping screews - this afternoon. Good result, no blue smoke after siting on sidestand, for first time in ten years.
44Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Wed May 16, 2012 1:40 pm
ReneZ
ReneZ
I better find out where I can get one ;-) And this after having lived in Canada!!
Rene
BMW K100 - 1985 (0030029) Scotland Permanent side stand puck Rain
45Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Wed May 16, 2012 2:26 pm
nino
ReneZ wrote:I better find out where I can get one ;-) And this after having lived in Canada!!
I can send it to you from Croatia. 1 GBP plus post expences to GB
46Back to top Go down   Permanent side stand puck Empty To Bosnia too? Wed May 16, 2012 3:56 pm
ffbikersa
ffbikersa
I would need one as well. Asked Motorworks & Motobins if they have one available, the answer was negative
47Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Thu May 17, 2012 5:53 am
ReneZ
ReneZ
Well, I don't expect the parts dealers to sell hockey pucks ;-)
Nino, like to take you up on that, just because I'm a lazy git! Just PM me how you want to deal with payment etc (PayPall??) and I can give you my address. Thanks!
Rene
48Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Thu May 17, 2012 6:27 am
nino
ReneZ wrote:Well, I don't expect the parts dealers to sell hockey pucks ;-)
I ll talk to guy in Hockeye center here in Zagreb. Puck (black or white) is very cheap (1 GBP) and could be my gift to brother in arms, but dont know about postage to Scotland. Have to ask
49Back to top Go down   Permanent side stand puck Empty Re: Permanent side stand puck Thu May 17, 2012 6:33 am
nino
Rene, send me your adress
50Back to top Go down   Permanent side stand puck Empty One for me too? Thu May 17, 2012 11:40 am
ffbikersa
ffbikersa
Nino, would it be possible that you get one for me too? Here in the bank should be no problem to get some Kunas, which I could put in the envelope to cover the postage & packing costs.
