1Back to top Go down   Blowing smoke on startup Empty Blowing smoke on startup Mon May 26, 2014 8:19 pm
Rockman
My 84 K100RT blows quite a bit of smoke when its first started after sitting a week or so on the centre stand. It eventually clears up when its warm, and it doesn't seem to be using any oil to speak of. My first thought is that the throttle bodies may need balancing, but are there any other suggestions? Its done 127000 km.
2Back to top Go down   Blowing smoke on startup Empty Re: Blowing smoke on startup Mon May 26, 2014 8:43 pm
ReneZ
ReneZ
Keeping the oil level above the centre dot when the engine is not running?
Rene
BMW K100 - 1985 (0030029) Scotland Blowing smoke on startup Rain
3Back to top Go down   Blowing smoke on startup Empty Re: Blowing smoke on startup Mon May 26, 2014 8:58 pm
brickrider
brickrider
Perhaps a leak-down test is in order?
4Back to top Go down   Blowing smoke on startup Empty Re: Blowing smoke on startup Mon May 26, 2014 9:06 pm
Rockman
ReneZ wrote:Keeping the oil level above the centre dot when the engine is not running?
dead on the centre dot when not running, and returns to there after.
5Back to top Go down   Blowing smoke on startup Empty Re: Blowing smoke on startup Mon May 26, 2014 9:10 pm
Rockman
brickrider wrote:Perhaps a leak-down test is in order?
Probably, but wouldnt it also use oil when warmed up an running if the rings were worn?
In any case, I'm not worried about it enough to do any major engine work, just wondering if there is a common cause.
Maybe I should also add that the idle when its cold and the choke is on is a bit "lumpy", but smooths out when its warm.
6Back to top Go down   Blowing smoke on startup Empty Re: Blowing smoke on startup Mon May 26, 2014 9:15 pm
I think the amount of oil needed to blow billows of smoke from a cold engine is actually very little.
You will probably find it is using oil (where else can it come from?), but the amount is negligible and is not noticed through the round window.
Blowing smoke on startup Images?q=tbn:ANd9GcTBiCPNwlrskU3jOlJgQBscZZq83agaOd1RABQ00TOACUIXypoK
Maybe we can ask Big Ted?
7Back to top Go down   Blowing smoke on startup Empty Re: Blowing smoke on startup Mon May 26, 2014 9:45 pm
Rockman
rosskko wrote:I think the amount of oil needed to blow billows of smoke from a cold engine is actually very little.
Big Ted knows all..
You are probably right. I think I'll just balance the throttle bodies, slap some new plugs in it and live with it. Somewhere I have a new set of injectors, so they might go in as well if I can find them.
