1 Stroke of luck. Sun Apr 06, 2014 10:02 am
xpc316e
I am in the midst of doing quite a lot of small jobs on my K1100LT. I have removed the ABS, put in braided stainless hoses, rebuilt the front forks, installed gaiters, fitted relays to the headlamp which now has a high wattage bulb and ceramic holder, fitted daytime running lights and spot lights to come on with main beam, oil change, and many other little jobs.
Today I thought I'd give the fan a spin, and discovered that it had seized. Off came the radiator, and by some stroke of luck I had bought a bargain radiator and fan assembly on ebay some months ago, so after confirming that the new fan did indeed work, I swapped it over to my old, proven radiator.
Of course, nothing goes smoothly; the two Allen screws holding the bottom of the fan to the rad had seized solid, so they had to be drilled out. Luckily, I had a couple of countersunk stainless screws in the spares box, so they went in.
It has all gone back together now, but I will be fitting an override switch for the fan, so that I can give it a short spin every time I use the bike.
Yesterday I discovered that there was a small spot of oil on the screw of the band that holds the gaiter to the swinging arm. I am hoping that it will be a rear drive input seal that has let go, but at least it will mean that the bike now gets a spline lube.
I am hoping that I eventually will stop finding jobs to do, so that I can actually ride the bike.
