1Back to top Go down   Gremlins Empty Gremlins Fri Mar 07, 2014 1:51 pm
nino
Hi everyone,
problems started as little disturbance between 1500 - 2000, more like hesitation. From 2000 pulled strong as usual.
After that no start at all, even with good battery, ignition coils&wires and spark plugs. Suddenly that dissapeared, engine started every time but not at once as usual. When hit button iz spins and spins and finnaly fire up. While runing same problem from begining hesitation on 1500 - 2000.
What to check. I cleaned most of contacts already.
P.S. I opened relay box maybe half an hour after ride and discovered only load shed relay was still hot. Does it mean anything?
Regards
2Back to top Go down   Gremlins Empty Re: Gremlins Fri Mar 07, 2014 4:51 pm
the load shed relay operates all the time that the bike is turned on nino .
except for when it is starting ...so normally would be warm to the touch....
do the headlights follow the fault ?       if so.... clean the starter brushes
we have seen some of those load shed relays become faulty on the contacts (which would also explain the high heat ).....and the socket that they plug into
have you thought about the ignition switch ...we have seen them needing a good cleanup after becoming intermittent ...I wonder if it has become vibration sensitive ?  or partially conducting when off
I am hoping that you have already cleaned the fuel tank connection contacts ?
all I can think of at this point .
good luck !!
3Back to top Go down   Gremlins Empty Re: Gremlins Fri Mar 07, 2014 8:28 pm
I would be checking for an air leak in the intake system, it sounds to me like it may be very lean at start up and up to 2000rpm.  May also pay to check the MAF (air flow sensor) is not sticking open a bit.
4Back to top Go down   Gremlins Empty Re: Gremlins Fri Mar 07, 2014 8:43 pm
kioolt
kioolt
I've said this before and if I am wrong I would like someone to explain it to me.  The load shed relay will not keep a bike from starting or running.  If you have a problem with your bike starting or running it is not the load shed relay.
Let me explain,  the purpose of the load shed relay is to turn the UNNEEDED load off when using the starter.  This gives more power to the starter, ignition and fuel injection system.  A failing load shed relay would show up as a headlight, radio, heated grip, etc. problem.  The ignition system, starter, and fuel injection system can not be disabled by a bad load shed relay.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
5Back to top Go down   Gremlins Empty Re: Gremlins Tue Apr 01, 2014 4:01 pm
nino
Finally I found what caused errraticaly idle and problems between 1500 - 2000 rpm. After I dissasembled fairing, checked air leak, changed spark plugs, measure resistance, etc, etc, the cause was very simple - broken brown (ground) wire on coil 3-4 cylinder. I knew from before that most common cause on old K could be stupid wire, but (again) didnt check obvious.
On the other hand this was opportunity to check and clean hidden places and contacts.
Thanks for help
6Back to top Go down   Gremlins Empty Re: Gremlins Tue Apr 01, 2014 4:13 pm
good find nino
success !!!!
