1Back to top Go down   Radio Help Empty Radio Help Sat Mar 15, 2014 3:08 am
CanberraDave
CanberraDave
I have had the genuine BMW radio out of my bike for a few weeks.  Reassembled it today and it now doesn't work. I put it back exactly how it came out (at least I think I did). Checked the fuse in the radio and the fuse on the bike.  Both good.
Could it be that the memory battery is now flat and needs to have some charge before the radio works?  Or do they just not like sitting on the bench for a few weeks?
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
2Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:12 am
The one in my RBike needs the unlock code entered into it after removing it from the battery. Sound like the problem?
3Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:28 am
CanberraDave
CanberraDave
When I turn it on it has no display to enter the code. It is almost like it isn't getting power.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
4Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:30 am
If it's a genuine BMW radio then a code is needed.
5Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:37 am
CanberraDave
CanberraDave
I have the code and have entered it but the radio display remains blank.  If it keeps going I will just fork out the dollars and replace it with something of a better quality and a bit more modern.  Should be able to do it for around $300 and still be able to use the handlebar remote.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
6Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:42 am
That's what I had to do with the car
7Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:46 am
CanberraDave
CanberraDave
I just thought there may be some special sequence when the radio has been out for a while.  Like reciting the rosary while standing on your left leg, turning the ignition on with your right big toe and holding every button on the radio down with all your fingers. What a Face
But thanks for the info guys.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
8Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 3:58 am
I'd be thinking a visit inside is needed, sounds like the display is not contacting with power, may be Verdi grease may be open circuit at a soldered point
9Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 4:06 am
Mine lights up when power is reconnected, I think the display shows b5 or something like that instead of the channel.
Did you try bashing it Smile
10Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 4:10 am
Good Idea, works great for TV's but not so good for men in pubs
11Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 5:11 am
just be aware that most of these new fangled radios have 2 wires to the ignition
1 has permanent power (called battery backup and is usually individually fused )
the other is wired to the power after the ignition switch (usually enables the power on function including backlight )
I wonder if the backup wire is not a good connection ......or you have spiked it (big power surge during reconnection to the battery .....like multiple arcs and sparks )
might pay to try disconnecting the battery for about 30 minutes ....and trying again ?
regards
12Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 6:09 am
Silly question.........have you turned the radio on by turning the volume knob clockwise?
Next..... try to push and hold down the ST button for a few seconds see if that change something.
13Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 11:32 pm
CanberraDave
CanberraDave
Well folks after going to bed complaining about Big Money Wasters and thinking I should not have to Bring Monstrous Wallet, I attacked the problem this morning from a calmer and more logical perspective.  I consulted the Bible and realised I was counting the fuses from the wrong side.  You guessed it - blown fuse.  Radio Help 61740   Replaced with a spare and now all is good.   Radio Help 723598
Given the above information K75cster, you can understand my reluctance to "visit inside".  Once I replaced the fuse the display was still blank, but did see the little light come and so put in the necessary code.  After 3 weeks out of the bike it even still remembered the station I was listening to (fogey fm for those who are interested).
As always, this forum is a constant source of valuable information and I appreciate all the comments.  Go on, you can tell me I'm an idiot now....you know you want to. Razz
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
14Back to top Go down   Radio Help Empty Re: Radio Help Sat Mar 15, 2014 11:41 pm
doesn't matter how it happens dave
as long as your in there trying ol mate
another one solved ......good for a giggle too ..
15Back to top Go down   Radio Help Empty Re: Radio Help Sun Mar 16, 2014 12:13 am
well done Dave , been down the same track( wrong direction) myself at times . it was great to get help here on the forum., good to hear you got on top of it.
luckily my Radio/ cassette is still operational. I visited the old Op Shops and fleabay  for a while just to get the old tapes to play in it.
you can buy the adaptor to run your Pod's and mobiles through. great for letting every one else "enjoy" your faves.
Radio Help 10_x_110
16Back to top Go down   Radio Help Empty Re: Radio Help Sun Mar 16, 2014 2:35 am
groverK wrote:well done Dave , been down the same track( wrong direction) myself at times . it was great to get help here on the forum., good to hear you got on top of it.
or just go buy a new jvc head unit with front and or rear mounted usb connection and Bluetooth for under a hundred and something ...
can carry heaps of old - new - weird stuff once converted to digital format ...on cheap as chips ...don't bounce, usb drives ,,, and they come in "din" size
just a thought ..
17Back to top Go down   Radio Help Empty Re: Radio Help Sun Mar 16, 2014 9:47 am
Or get a Pioneer MVH-P7300 (the 8300 has BlueTooth) that uses SD cards or USB with a CD-MR50 waterproof marine remote. Then you can watch Easy Rider while you're riding.
Radio Help Cdmr79
Radio Help Mvh7300
