1Back to top Go down   Gearbox Bearings - Replacing Empty Gearbox Bearings - Replacing Sun Mar 30, 2014 4:40 am
floyd
floyd
Im really unsure about my gearbox bearings. Ive got it stripped down and ready to go back together, Im just unsure of the state of the bearings, as Ive not got much experience in judging such things. (NB: Incase your wondering....I opened it to replace all the seals, and also because im a curious s.o.b)
While im this deep in the box, and also considering its a 220,000km bike, should I just replace the bearings anyway?
I have another intact gearbox here of slightly newer vintage, perhaps ill open it and compare its bearings with these ones, for reference....
In Aus, is it cheaper to buy the suitable bearings from a local bearing shop, or is the Bins still the cheapest option?
If I just dropped the shafts and new bearings off at a bike mechanic would they be willing to do the swap for me? How many hours labour do ya reckon that would be? Only 1 I would hope.;..?
Or anyone wanna lend me a bearing splitter/puller/whatever other special bits are needed?
2Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 5:09 am
They are very common sizes and should cost no more than $70 including the seals even buying a high quality brand like SKF or Timken.
3Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 5:12 am
floyd
floyd
RicK G wrote:They are very common sizes and should cost no more than $70 including the seals even buying a high quality brand like SKF or Timken.
Each or for the set?
4Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 5:20 am
The whole six. One of the tapered roller bearings is the same as a front wheel bearing for a holden
5Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 5:27 am
floyd
floyd
RicK G wrote:The whole six. One of the tapered roller bearings is the same as a front wheel bearing for a holden
Wonderful. Bearing shop - here I come...
Hmmmm to do it my self or not do it my self. That is the question....
 Twisted Evil Do it do it dooooo it  Twisted Evil
 Gearbox Bearings - Replacing 78846  Gearbox Bearings - Replacing 78846  Gearbox Bearings - Replacing 78846
6Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 6:32 am
floyd
floyd
Ok, I think I have all the specs for my K100RS gearbox and K100/K1100 hybrid frame/front end....
Correct any of this those of you in the know....
Steering Head                                   -TAPERED ROLLER BEARING            -28X52X16                                 -2
GB OutputGROOVED BALL BEARING20X47X14MM1
GB OutputGROOVED BALL BEARING25X52X15MM1
GB InterGROOVED BALL BEARING17X47X142
GB InputTAPERED ROLLER BEARING45,24X16,64X221
GB InputTAPERED ROLLER BEARING45X19,05X15,51
7Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 7:22 am
don't forget there is a preload on the fitting up Floyd ...the Haynes manual describes this pretty well
good luck mate !
8Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 7:25 am
When you get the ball races they will have a rubber seal on both sides just put a sharp screwdriver and get rid of the seals (they come very easily). You can get the shielded bearing with a steel shield on both sides but they are heaps more and not really needed.
9Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 7:26 am
floyd
floyd
floyd wrote:Ok, I think I have all the specs for my K100RS gearbox and K100/K1100 hybrid frame/front end....
Steering Head                  .TAPERED ROLLER BEARING                                                       .28X52X162
The input bearing measurements seem weird...???
Thanks charlie!
10Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Sun Mar 30, 2014 7:57 am
3/4 inch and 5/8 inch
One more thing is when you remove the cover make sure not to mix the shims, They will probably be stuck to the inside of the cover with thick gooey oil. Keep an eye for them often you don't pick up they are there till washing is complete and they are in the tub and don't ask.
11Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Mon Mar 31, 2014 2:38 am
floyd
floyd
RicK G wrote:3/4 inch and 5/8 inch
Already made that mistake and mixed the shims up.....
Just went to the bearing shop and they were mighty pissed off that I didn't have a specific number for each bearing, only the measurements (they seem to be continually amazed that the general public are oblivious to the nuances of the bearing world)
One bearing in particular, he reckons does not exist, based on the specs I got from a micro fiche (45.24 X 16.64 X 22)
Bearing in question is the closest to the splines on the input shaft.
Anyone have these mythical numbers?
12Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Mon Mar 31, 2014 3:15 am
you haven't seen this yet Floyd ?
you might have to get the password for the downloads section ?
oopps disappeared
13Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Mon Mar 31, 2014 3:17 am
floyd
floyd
No I hadnt seen it Charlie, but literally seconds before you replied I stumbled apon it via google :0
What a fantastic resource. This forum makes me so glad I bought a K bike!
Thanks mate, that should keep them happy.
14Back to top Go down   Gearbox Bearings - Replacing Empty Re: Gearbox Bearings - Replacing Mon Mar 31, 2014 4:51 am
you realize I will have to remove the direct link to the downloads section ...hope you got it bookmarked
have fun Floyd ...and stick it up those bearing guys .....
