1Back to top Go down   fuel tank vent & overflow hoses Empty fuel tank vent & overflow hoses Mon Mar 17, 2014 6:49 pm
emmanuelfiadjoe
emmanuelfiadjoe
i had to replace a burst fuel pipe and needed to take off the tank. on refitting, i'm confused which of the small two close hoses is the vent & the overflow
2Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Mon Mar 17, 2014 6:54 pm
The rearmost is water drain (from around outside of filler cap).
The frontmost is the vent (from a pocket inside the top of the tank).
3Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Mon Mar 17, 2014 7:01 pm
emmanuelfiadjoe
emmanuelfiadjoe
thanks man, but my problem is which of the two hoses should connect to the vent stub, or can i connect any of the two hoses to either overflow or vent?
4Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 3:12 am
emmanuelfiadjoe
emmanuelfiadjoe
can any of the two small hoses under the right side of the tank connect to any of the stubs u'v described above?
5Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 3:31 am
MikeP
MikeP
I've never seen a hose attached to either.
There should be a small rectangular "cup" that hooks over the frame tube and drains via a tube down behind the right footrest plate. The two fuel tank fixed tubes simply sit in the "cup".
fuel tank vent & overflow hoses BMW%20K75S%20%28371a%29-XL
1992 K1
6Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 4:02 am
The real early models had a rubber tube attached to both the outlets but I don't know if there is any difference to the hoses.
7Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 4:28 am
MikeP
MikeP
RicK G wrote:The real early models had a rubber tube attached to both the outlets but I don't know if there is any difference to the hoses.
Ah. I've always steered well clear of the early "Beta" versions.  fuel tank vent & overflow hoses 652573
1992 K1
8Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 5:05 am
I usually steer well clear of the first of a model too. Laughing
9Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 5:14 am
didn't the early ones have a breather tube from the gearbox or some such thing as well ....
but basically both should lay along the swing arm as an exit ?
I don't think the cup happened till the 85-86 changeover  ?  (still stinks of fuel vapour from under there on really hot days )
10Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 6:26 am
Must vary by country.  My 90 K75RT had hoses attached to both.
11Back to top Go down   fuel tank vent & overflow hoses Empty Re: fuel tank vent & overflow hoses Tue Mar 18, 2014 7:26 am
Being that they are vents from a fuel tank that is likely.
