1Back to top Go down   HELP! vent hose & overflow hose Empty HELP! vent hose & overflow hose Wed Mar 19, 2014 11:45 am
emmanuelfiadjoe
emmanuelfiadjoe
pls, there are two small stubs under k100rs fuel tank on the right. I understand one is for vent & the other for overflow. my problem is which of the two hoses should be connected to which stub? I had to take off the tank for me to do a repair & I'm unable to determine the corresponding stubs for the two small hoses on the right under tank because they are very identical.
my problem is the hoses not the stubs.
thanks
2Back to top Go down   HELP! vent hose & overflow hose Empty Re: HELP! vent hose & overflow hose Wed Mar 19, 2014 12:26 pm
As far as I know it doesn't matter
3Back to top Go down   HELP! vent hose & overflow hose Empty Re: HELP! vent hose & overflow hose Thu Mar 20, 2014 9:36 am
Erman
Erman
As long as you run both hoses towards the rear/bottom of the bike, you should be good. Just make sure they run to the left or right, and not the middle where the fuel may come into contact with your rear wheel.
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
