1 Stalling engine Fri Mar 07, 2014 4:03 am
If I use the throttle gently and cut the throttle everything is OK.
If I sharply blip the throttle to 3000 or above or have to come to stop from higher revs like pulling up for traffic lights, the engine slows so much that it stalls.
Also when the revs are dropping down quickly through 2000-1500, the charge light comes on then off.
The bikes idle speed is good at 1000rpm, it just drops off so far when decelerating that it sometimes stalls.
Hopefully the stalling will be sorted once I get the injectors cleaned and synch the throttle bodies. I've never seen the charge light flash on like that before.
Any ideas?
Any ideas?
'93 K1100LT
