1Back to top Go down   Fuel pump Empty Fuel pump Thu Feb 27, 2014 4:12 am
nino
Hello all, yesterday after start pump of my K 100 8V became noisy even the tank was full. Engine doesnt work well between 1500 - 2500, but from 3000 OK. Noise from pump didnt dissapear totaly, it sounds like tank was empty?
Is it time to change weak pump, or could be something else (fuel filter is new)? Any suggestions?
2Back to top Go down   Fuel pump Empty Re: Fuel pump Thu Feb 27, 2014 7:27 am
fuel regulator ???
or did you pick up some bad fuel nino ?
might be an idea to drain the tank and start again with some good fuel ? before anything else
3Back to top Go down   Fuel pump Empty Re: Fuel pump Thu Feb 27, 2014 7:41 am
nino
Charlie, probably bad fuel from gas station in my neighborhood known for water and mud in gasoline (56 instead 95 octanes). I was in a hurry.
I have 6-7 ltrs remained in tank so its better to wait few days and fill new fuel 98 somewhere else.
4Back to top Go down   Fuel pump Empty Re: Fuel pump Thu Feb 27, 2014 11:20 am
k75RT Keith
k75RT Keith
As a possible temporary fix, try using some dry gas to absorb the water.  If the station is known for dispensing mud, you might consider changing the filter and the sock on the fuel pump
5Back to top Go down   Fuel pump Empty Re: Fuel pump Thu Feb 27, 2014 1:15 pm
nino
I changed filter and put Liqui moly fuel system cleaner. Ill try with 98 gas.
6Back to top Go down   Fuel pump Empty Re: Fuel pump Thu Feb 27, 2014 3:32 pm
brickrider
brickrider
I'd change gas stations!  Shocked
