all done for now. moved the earth , as Charlie suggested, to the pannier frame bolt under the rear cowl.
I did test the earth through the towball , which is also attached via the same pannier bolt. No luck.
Ran a test probe from the pannier bolt to the number 1 pin (earth) where the trailer connects , positive result, with turn signals and taillights working.
I'm not happy with the white wire exposed though, for me it's a bit like a WHITE cable tie!!!!!!! just doesn't look right.
so the end result is , trailer harness wiring is easy . once you know how . Thanks to the assistance of fellow forum members.
WIRING YOUR K FOR TOWING A TRAILER
installing / wiring a trailer harness to your K100 / K75 / K1100
step 1. remove taillight to expose wiring under tail cowl.
step 2. BE SURE NOT TO CUT INTO ANY BROWN ( Earth ) wires. leave these intact.
step 3. cut, strip and prepare the following wires:
left and right turn signal
brake (stop)and taillight (parking)
step 4. with your hitch harness cable , strip and prepare the corresponding wires for connection, ie ; turn signals, brake , taillight , and earth.
google : Trailer wiring , for your colour codes.
step 5. crimp individual female connectors to all lighting wires leading on to your power source.
step 6. start pairing up harness wires with corresponding light utilities,and twist together
ie; bike brake light wire with harness brake wire. bike taillight with harness taillight etc , etc
step 7. when pairing is complete, insert these into individual male connectors.
step 8. continue by connecting the previously prepared female connectors to the male connectors.
step 9. find a good earth ground on the bike , such as the z frame bolt under the tail cowl, and attach the hitch harness earth wire to this point.
just remember , as pointed out previously , K bikes have BROWN earth wires, and trailer harnesses have WHITE earth wires.
so be careful when colour coding wires together.
step 10. run a test on all lights and earthing, by means of multi meter or test light (with probe spike). I used the latter, it was simpler.
step 11. reassemble all tail components .
you are now ready to hitch up your favourite trailer and start touring.
