1 Locations of all grounds on K100rs Sun Feb 05, 2012 4:13 am
FreebasserSF
Lately I've suspected that one or more ground may be corroded somewhere in one of the nooks or maybe crannies of my bike. I have used deoxit as many here have recommended and cleaned as many of the obvious connections I could with steel wool, wire brushes, deoxit, files, and sandpaper. Please tell me which grounds I may have missed. I have "treated" and made sure were properly grounded all of the following ground wires: the obvious cluster of brown wires under the gas tank, the one to the engine directly from the negative battery terminal, one to a bolt behind the footpeg mounting bracket, one on the starter (or maybe it's the alternator, I can't remember). If anyone could post a complete list of all grounds that are to the frame or to some component which eventually goes to the frame that would be even better than telling me the ones I missed. Also a BMW mechanic told me via email that a bolt toward the right rear side of the frame, a bolt which holds the engine to the frame has a ground and looks like this:
Can anyone clarify what he's talking about? I can't seem to find a wire leading to that spot on my bike...
