1Back to top Go down   loose nut on final drive Empty loose nut on final drive Thu Dec 12, 2013 2:05 pm
Johnser
Johnser
Hi again,
Just lubing my final drive splines as I had the wheel off for a tyre change.
When I got the final drive off, a tablespoon of oil fell out of the shaft/FD.
Strange, I thought, as the area was dry when I lubed the splines in the spring. and no signs of leaking oil when parked or around the drivetrain.
However, on inspection, the nut that winds onto the FD splines was loose!
So my questions are:
-Why might the nut come loose? too harsh a downchanges?
-Is that likely to be the cause of the leak? or from somewhere further up towards the 'box..?
-I take it there's a seal in there too somewhere.... replace it before I torque the nut back up, or whack it back together and see how it goes?
-use some kind of locking device/locktite to try to keep the nut in place?
Any opinions/experiences gratefully received!
2Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 3:04 pm
mike d
It's not unusual to find a drop of oil, but if it gets worse you may need to replace the input pinion oil seal (it sits in a threaded ring). How does the drive feel? Perhaps the input bearing is worn?
That nut should be at 200Nm!
Mike
3Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 3:06 pm
MikeP
MikeP
Do you mean item #1 in this?
loose nut on final drive B0004418
1992 K1
4Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 3:34 pm
Johnser
Johnser
Thanks for the replies,
Yea, #1 in the diagram. Thanks for that pic - most helpful
I will double check in a bit, but the brief examination I gave it showed no signs of a worn bearing, couldn't feel any in/out play, roughness or side to side movement.
The moly-grease that had been flung off of the splines from the previous lube had not been dissolved by the puddle of gear oil, I'm hoping this suggests it might be a fairly new issue and I havn't caused too much unnecessary wear on the pinion/crown.
I take it #4 is the seal so it shouldn't be a huge hassle to replace it so long as I can get #3 out.
5Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 4:04 pm
mike d
Yep, #4 is the seal. There is a tool for the threaded ring...........
loose nut on final drive <a href=loose nut on final drive 31700PinWrenchsocket_zps693c03b5" />
6Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 4:17 pm
Hi Johnser,
Here's a simple tool for locking the bevel box while you try to reach 200Nm!
https://www.k100-forum.com/t3247-simple-bevel-box-locking-tool
7Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 5:53 pm
Johnser
Johnser
Heh, thanks. That tool would've been perfect!
I was scratching my head about how to hold it and in the end put the wheel on, held the square end of the casing in a vice and clamped chocks onto the disk to butt up against the brake mounting holes. With a further brace bar lodged between the wheel spokes it was just about possible to get the torque up to 200Nm.
Very heath robinson and I kind of wish I'd seen that first.
So yea, I decided to whack it back together and see what happens.
cheers!
8Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Thu Dec 12, 2013 5:59 pm
Good for you. Where there's a will, there's a way. cheers
(Reminded me of a MAD magazine quote "Where's there's a will, there's relatives!)
9Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Fri Dec 13, 2013 4:35 am
loose nut on final drive 44271
10Back to top Go down   loose nut on final drive Empty Re: loose nut on final drive Fri Dec 13, 2013 4:38 am
sidecar paul wrote:Hi Johnser,
and a great idea paul
made one just last week....hoping I can borrow caferacers "ring release tool" one day for the unlocking of the pinion ...
