1 loose nut on final drive Thu Dec 12, 2013 2:05 pm
Johnser
Hi again,
Just lubing my final drive splines as I had the wheel off for a tyre change.
When I got the final drive off, a tablespoon of oil fell out of the shaft/FD.
Strange, I thought, as the area was dry when I lubed the splines in the spring. and no signs of leaking oil when parked or around the drivetrain.
However, on inspection, the nut that winds onto the FD splines was loose!
So my questions are:
-Why might the nut come loose? too harsh a downchanges?
-Is that likely to be the cause of the leak? or from somewhere further up towards the 'box..?
-I take it there's a seal in there too somewhere.... replace it before I torque the nut back up, or whack it back together and see how it goes?
-use some kind of locking device/locktite to try to keep the nut in place?
Any opinions/experiences gratefully received!
