1Back to top Go down   front fender assembly Empty front fender assembly Fri Dec 06, 2013 12:19 pm
martyman
martyman
front fender assembly IMG_0757_zpsf60b9fd7
Can someone tell me if there is a pdf or tell me the order of the bolt with washers, plastic tab for the main bolt holding the front fender on my K100 RS?  my Hanes manual is useless.
thanks
2Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 1:16 pm
Brad-Man
Brad-Man
Assuming you have an early K - one piece fender, then look at This...
3Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 1:34 pm
martyman
martyman
Brad-Man wrote:Assuming you have an early K - one piece fender, then look at This...
Thanks brad, its close, could help I will try...bounce
4Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 2:15 pm
In Picture in the first post....the part of the plastic tab that holds the nut is missing.
front fender assembly Skjerm11
5Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 2:25 pm
martyman
martyman
Inge K. wrote:In Picture in the first post....the part of the plastic tab that holds the nut is missing.
ok here is the fender and pieces, yes I have two plastic tabs, tried a dozen different combinations of how to put it together.
front fender assembly IMG_0759_zpsec4b66c5
6Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 2:32 pm
orforester
orforester
The two plastic tabs are to secure the brake lines to the reflector bolts.  They have nothing to do with securing the two halves of the fender, I believe.
They attaché to the back side of the reflector bolt, the rear one and secure the brake line so it doesn't get in or scrape the tire, I would assume.  They are also a bear to get all the parts lined up with the brake line and washers, plastic parts.  First time is tough
Bob
7Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 2:34 pm
In last Picture it's the two piece fender used on the 16V model, I think you got a older model or?
8Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 2:35 pm
martyman
martyman
orforester wrote:The two plastic tabs are to secure the brake lines to the reflector bolts.  They have nothing to do with securing the two halves of the fender, I believe.
Bob
Life saver bob...when disassembling pieces just dropped to the floor and I didn't get to see where they were, thank you very very much...
edit, the two thick washers do not seem to work either...bolt won't reach with them.
9Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 2:38 pm
orforester
orforester
No Prob, has happened to me also!
10Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 3:06 pm
It does help to put your model and year into your signature. I would have known that it was a 16v model and could have taken some photos of mine, but I had no idea!
11Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 3:31 pm
martyman
martyman
bikerboy wrote:It does help to put your model and year into your signature. I would have known that it was a 16v model and could have taken some photos of mine, but I had no idea!
To be honest Im guessing mine is a 8 valve?  have not opened my valve cover yet.
Finally found it thanks to that PDF file...fantastic
http://www.maxbmwmotorcycles.com/fiche/Diagrams/B0001051.png?v=04302013
12Back to top Go down   front fender assembly Empty Re: front fender assembly Fri Dec 06, 2013 7:39 pm
Is your bike a K75 Marty. That looks like a K75 type guard and not the K100 16v two piece.
