1Back to top Go down   firmer back end Empty firmer back end Sat May 10, 2014 9:46 pm
petek100rs
petek100rs
I have a stock rear shock on. My bike is way under sprung with the double hrd fitted. My problem is im broke and cant afford a new shock. I have been looking at mono shocks that are the same length. Has anyone tried this? I also want to put a brace on the lower mount for the rear shock. Has anybody got some pictures they could post as I dont really know how it should look.
Thank you
2Back to top Go down   firmer back end Empty Re: firmer back end Sat May 10, 2014 9:56 pm
Dale S
Dale S
check out "studs, who wants a stud", by ainsjack in frames & fairings.
An elegant solution to a brace! Cool
1990 BMW K100LT
 2003 BMW 540i
 1998 Ford f-150
3Back to top Go down   firmer back end Empty Re: firmer back end Sat May 10, 2014 10:42 pm
petek100rs
petek100rs
Thank you
4Back to top Go down   firmer back end Empty Re: firmer back end Sat May 10, 2014 11:11 pm
I know some have constructed the brace in such a way that it allows a second shock mount. Instead of a stronger shock, use 2. No pics sorry.
'93 K1100LT
firmer back end K-dogs10
5Back to top Go down   firmer back end Empty Re: firmer back end Sat May 10, 2014 11:49 pm
The paralever read drives are a different shape and you cant use that type of brace. Instead of the flat surface below the nut it's rounded and a brace wont work.
I have been trying to think of something since my stud broke but haven't come up with a solution.................yet!
But I do think it will mean taking the drive to bits.
6Back to top Go down   firmer back end Empty Re: firmer back end Sun May 11, 2014 4:44 am
petek100rs
petek100rs
I look at the curved surface of the paralever diff and couldnt see how it might get sufficient footing. I thought maybe a piece of steel that formed a u shape with the bracket mounted on the stud either side of the shock eyelet and the lower part of th u bracket hugging the curves of the paralever diff. It might take a little while to get it seating right. Thats all I could come up with.
7Back to top Go down   firmer back end Empty Re: firmer back end Sun May 11, 2014 9:10 am
saw this at Karuah rally last year
firmer back end 2013-018
hope it helps
and got a rear shock rebuilt for seans k100 ....he reports it has made things a bit better  but I would be looking to get something that has adjustable damping and rebound ....like a "ram" shock  ?
8Back to top Go down   firmer back end Empty Re: firmer back end Sun May 11, 2014 9:29 am
I wouldn't think you could do that with a stock setup. I think the boss where the stud goes has been machined back and the bottom of the shock doesn't look as thick as I recall.
On my K1100 rear drive I have tried to fit a plate there and there is nothing but a very angled face and no where to support it.  Possibly the K100RS16v is a bit different to the K1100 but I don't think so.
9Back to top Go down   firmer back end Empty Re: firmer back end Mon May 12, 2014 8:03 am
petek100rs
petek100rs
Your right rick mine sits out further too. I wonder if the movement created by the paralever action would cause wear on the stud?
10Back to top Go down   firmer back end Empty Re: firmer back end Mon May 12, 2014 8:27 am
Don't know if wear is the word but my stud is bent after last weekend to Nindigully and probably due to break. It was replaced this time last year and has done 8000km.
I actually have a few ideas on it so might do some machining in the next few days and see what falls out of the mill except for swarf.
11Back to top Go down   firmer back end Empty Re: firmer back end Wed May 14, 2014 7:06 am
petek100rs
petek100rs
The pick of the brace seems to have a white power shock ive been looking at putting on. Its off a ktm trail bike and close enough to the right length. Its off a small bike but is a mono shock so the spring should be stronger than stock without being rock hard. The eye width is narrower maybe thats how the bracket was able to be fitted.
