erik m
erik m
Having removed the fairing, quite a few other things also disappeared.
First, I needed a headlight mount- luckily I already had a steel fencepole, and cut off a piece.Mounting of headlight, signals, signal horn - and led daylights. Lykt213
 I then made a 40 mm split in the angle in both ends, cut off the vertical part and bent up the horizontal part - thus I also had a mount for the signals. By a square bit of thinner metal I could fix the horns to the same 6mm bolts that went into the part connecting the forks.Mounting of headlight, signals, signal horn - and led daylights. Lykt111
Mounting of headlight, signals, signal horn - and led daylights. Lykt510
Many years ago I learnt the hard way the benefits of being seen, so I put two yellow 3W LED lights on each side of the headlight. Those i fastened to the windscreen.Mounting of headlight, signals, signal horn - and led daylights. Lykt410
Finally I cut four holes through the back of the top-box, behind the red reflecting glass, and put in four 1,5W led-lights; two connected to the tail-lights, andt two to the braking-lights.
Last edited by erik m on Sun Dec 01, 2013 5:20 pm; edited 7 times in total (Reason for editing : Several failed attempts to add pictures.)
Velkommen, ta en titt på dette: https://www.k100-forum.com/t998-posting-pictures-and-Movies
Dette er en tidligere versjon, men ikke helt ulikt dagens oppsett.
erik m
erik m
Takk skal du ha, Inge, men - det var det jeg resonnerte meg fram til, og forsøkte fire-fem ganger, men det kommer allikevel ikke inn. For å være mer presis: når jeg trykker "copy" i det andre bildet, forsvinner alt.
DER satt'n! ISTEDETFOR å trykke copy merka jeg feltet, høyreklikka og fikk opp nytt bilde med valg, valgte kopier, klikka meg ut av posten, gikk tilbake til posten igjen, valgte "edit" igjen, høyreklikka og "limte inn" linken. Lurte pc-nissen!
Eller...etter at du har trykket copy, trykker du på knappen/symbolet av en skjerm med et pluss
tegn i et nedre høyre hjørnet...deretter dukker det opp en pop up.....du limer inn det du har kopiert i adressefeltet på denne pop up'en.
Mulig det er enklere?, uansett det er i allefall slik jeg gjør det...........
Inge K. wrote:Eller...etter at du har trykket copy, trykker du på knappen/symbolet av en skjerm med et pluss
God forklaring Inge.
Jeg kunne ikke gjøre det bedre ...
Very Happy (Thanks to Google translate)
Mounting of headlight, signals, signal horn - and led daylights. Frog15Mounting of headlight, signals, signal horn - and led daylights. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
wouw  Shocked   Laughing..........Your mother in law was from Norway, wasn't she?
erik m
erik m
Nei, det er akkurat det som ikke funker for meg - for når jeg trykker "copy", forsvinner hele linken. Det sitter nemlig en liten nisse inni pc'n min, som jeg glemte å gi graut på julaften. Men som sagt, jeg lurte'n allikevel. Tipper våre engelsktalende venner klør seg godt i hue nå!Laughing
Det kan muligens bero på operativsystem, har benyttet denne framgangsmåten i XP uten problemer
så langt.
Har nå prøvd 8.1, der fungerer det tydeligvis ikke på samme måte...............
Tja, de fleste her som er nysgjerrige nok, har tilgang til Google translate.....
Inge K. wrote:wouw  Shocked   Laughing..........Your mother in law was from Norway, wasn't she?
Yes, but she was the last one of the family (living in Canada) fluently speaking Norwegian. All the kids lost it and they use  English when communicating with their Norwegian cousins. Crying or Very sad
Marker linken og hvis du bruker en PC, trykk Ctrl + C i stedet for å trykke på kopiknappen
Spend a lot of time with your mother in law, didn't you............
