1Back to top Go down   Odometer speedo issues Empty Odometer speedo issues Sun Jan 19, 2014 4:57 am
Hi guys / girls....went for a nice ride with the lads today to the Goulburn swap meet and it was pretty crappy from a K100/75 perspective with one bucket of broken bits on offer imagine the 4 of us around it looking down in disgust...but I am off the track a bit....anyhow on the way back I lost the odometer or more to the point it stopped moving the speedo was fine but KM's to refuel was absent ...i did manage to put 19.5 litres in the old girl the most I have from memory.
So who can tell me the link to the most recent repair troubleshoot entry.
i have 2 spare sets of clocks and fitted one this afternoon and all is great except no speedo on this one no idea if odometer also...suspect so. my last choice has 182, 000 kms on it so suspect it also has issues to be confirmed.
So a clocks workshop may be in order...what to look for and where parts are available if needed like cogs etc.
so how many revs for how many km's in top gear kids?.....
Cheers Klompy
KKlompy Odometer speedo issues 2854237993
Odometer speedo issues Au-log10
2Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Sun Jan 19, 2014 5:08 am
many posts klompy
but by far the best way to adjust the speedo is with the software for the pc ("Karumba" ?) ....taken out the headphone jack and then to the sensor cables to produce the pulses required ...but are the same across all the variations of the models ...the impeller setup doesn't change at all for all the monoshock rear ends
I was looking for the gears as well
seems we can get them here in aussie  relatively cheep (but you need to know the gear count per cog for the instrument you have fitted it appears ) many sites quote different numbers ))))
from memory 3850 -3900 or so gives 100 kph in top gear on the rs diff ratios
4100 round about on the rt -lt for 100kph
be back with the links
try this first up
https://www.k100-forum.com/t4122-odometre-gears-availability-in-Australia
have a look here also
http://www.odometergears.com/products/BMW/R+%26+K+Motorcycles/42
inge and quite a few of us have used the duplication (fine cables soldered point to point )  method to fix the plastic circuit from the input pins on the cluster to the speedo drive motor and amplifier circuits ...it isn't too hard ....but a couple of tricks in there
hope that helps
btw im after gears as well ...don't know which exactly just yet as gerty is the only transport at the moment
but will pull the instruments apart soon
3Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Sun Jan 19, 2014 5:23 am
charlie99 wrote:many posts klompy
Karamba  Smile
https://www.k100-forum.com/t2038-karamba-speedometer-calibration-program-tutorial
Odometer speedo issues Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
4Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Sun Jan 19, 2014 5:42 am
try this first up
hope that helps
no shortage of broken ones here mate you can borrow...or we can fix for swaps etc...I will need to pull them apart and see what is what...but i do know I have 2 RS units and one RT (ex police)....is there a noddy's guide to opening these up without destroying them?
5Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Sun Jan 19, 2014 5:45 am
6Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Sun Jan 19, 2014 6:37 am
this link to oldgoats resto might help klompy
https://www.k100-forum.com/t1941p450-85-rs-restoration-part-1#19480
but I think sidecar paul has some detailed pics of the whole process ...cant find them just yet
hope it helps
7Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 3:54 am
started pulling her apart and lookie what i see...
Odometer speedo issues Goulbu10
Odometer speedo issues Goulbu11
Odometer speedo issues Goulbu12
Odometer speedo issues Goulbu13
Odometer speedo issues Goulbu14
Odometer speedo issues Goulbu15
Odometer speedo issues Goulbu16
Can you find the missing screws??
Last edited by Klompy the grey brick on Mon Jan 20, 2014 4:30 am; edited 1 time in total
8Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 4:04 am
Are you seeing something I am not?
Are you seeing....things?
Is it the sticker?
Are you missing a washer?
Can I borrow your glasses?
Is there a dead people?
9Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 4:26 am
10Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 4:28 am
malcoops
malcoops
Missing pin?
Laugh and Laugh Often
bmw kl1100lt, 1993, honda cx500 1978, honda gl500 1982, and bits and pieces
11Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 5:39 am
lots and lots of broken bits of plastic inside......oh well swaps time with the others...
Odometer speedo issues Sam_0013
12Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 6:23 am
All fixed and now I is a Constable,,,,,,,,,,,,,,,
Odometer speedo issues Sam_0014
13Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 6:59 am
The newer cluster have a pcb which work together with a switch type float level sensor in the fuel tank.
(If you got the genuine tank for your model you have a thermistor level sensor).
If you want the warning lamp to function properly, you need to swap the pcb to one to be used together with the thermistor sensor.
(and you need one for a 9 screw cluster, the one in the 7 screw cluster earlier in this thread won't fit).
14Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 7:39 am
broken - split teeth klompy ?
good result mate
good to have spares on hand ...huh ?!
and I notice you've lost a few killometers as well ....giggles
15Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 8:08 am
The rear of the Speedo was trashed all the plastic busted surprised anything worked....all gears are good and stowed away for use later...now to convert a post 85 to pre 85 use for fuel indication.....swap a PCB apparently is all that is required....conductive tape apparently the same....excellent more knowledge...
16Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Mon Jan 20, 2014 3:11 pm
Great to see your work. Now you need to practice your skills. When do want mine?
17Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Tue Jan 21, 2014 2:16 am
I do have enough bits to help post 85 guys out with specialised bits....Inge any reason why these PCB's are different...both is/was fitted to a 7 screw 7litre/4litre orange /red thingy.
Anyhow the unit I have fitted now works great although I may never know I am out of fuel until I am walking so want to change PCB...even if it only gives me the last 4 litre warning.
Ideas?  at this stage its an easy fix to swap Tacho assemblies and it should be tickety boo...yes Inge?
Odometer speedo issues Sam_0015
Odometer speedo issues Sam_0016
Odometer speedo issues Sam_0017
18Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Tue Jan 21, 2014 3:24 am
The fuel level pcb which still is mounted is a 7 screw model, to be used together with the thermistor sensor and 4 + 7 L warning.
It was also a later model of the thermistor pcb using only the 4 L lamp, those was aviable in both 7 and 9 screw models.
The single pcb in the pic is one to be used together with a float sensor, 5 L warning and 9 screw only.
That it was in a 4/7L, 7screw cluster.....I'll guess that the cluster have been used on a later model bike With a float sensor.........or the genuine bike have changed the fuel tank to a newer model.
19Back to top Go down   Odometer speedo issues Empty Re: Odometer speedo issues Tue Jan 21, 2014 4:26 am
Thanks Inge that sounds right as this was a unit that had been played with in the past...lots of new bits and a screw broken inside...so although it had 4 and 7 it was a 4 only unit ...the missing bulb and pristine holder was another hint....ex police low km's ...must have fallen over at some stage.
anyhow tacho unit changed, a small amount of filing as new tacho housing had one less screw groove on lip.now fitted all works but will need to reduce fuel to see if that works now.....fingers crossed and good comfy walking shoes on tomorrow.....
Odometer speedo issues Girls-10
