Should I replace these when I check my valves? K75valvegrommetsd
The're OK mate the cracks are only half way through you should get another 25 years from them. Just cover them in that red gorilla snot till it dribbles down the cover and they wont leak any significant amount of oil.
lol!
Nah, the bolts look in great shape.Very Happy
MikeP
MikeP
Don't check your valves.
Sorted.
1992 K1
AJ.Valente
AJ.Valente
Ya, mine look the same. I checked-out the procedure for changing the valve cover gasket and decided that discretion being the better part of valor I'd let my mechanic do it when the time comes. :king:
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
aww aj ...that is sad ...it aint hard
just make sure you have the bolt rubbers ....AND replacement cover gasket ...BEFORE you start ..they aren't expensive at all  and by replacing ....will last another 20
ReneZ
ReneZ
Yes, you should. These grommets keep the pressure on the seals, as the bolts bottom out. There is very little, if any pressure from the bolts on the cover seals, its all coming from the 'bolt-grommets'. They're not expensive and if you warm them up and use a bit of grease easily replaceable. The old ones will be difficult to replace (I cut them all off last year) as the grommet is hardened out.
Rene
BMW K100 - 1985 (0030029) Scotland Should I replace these when I check my valves? Rain
FYI: I just posted that pic for entertainment purposes because those are the worst of those I've ever seen.
I'm installing all new grommets and gaskets on both sides.
I cut the old ones off too.
Knowing its you, Duck, and your sly sense of humor, one must take this post tongue-in-cheek.  Smile
rawdonball
rawdonball
Valuable lessons for us newbies while the "die hards" share jokes. Keep it up please. Much appreciated!
12Back to top Go down   Should I replace these when I check my valves? Empty No1 Spark plug looks skewed crossed? Sun Nov 24, 2013 6:48 am
mawhera
mawhera
my no1 plug wouldn't fit the socket it looks a bit offf centre, could be crossed or PO helicoiled a bit out?? no leaks, Mananged to do 2,3,4 plug replacement no prob, no1 puckeroooed perhaps, leaving it for now having a think, a slow one till i get back from the Burt Munro..
re valve tappet clearance, how often in kms approx, are the shimms hard to get? my odo says 28 000 kms so shes a little used bike or new speedo??
Rick
Should I replace these when I check my valves? Nz_log10
Rick
K IWI land
New Zealand
28000 ? ...still getting runned in ....check them again at 50,000
Just a little of this should keep 'em looking good, and get you through tech inspection. It worked for Burt. Wink
Should I replace these when I check my valves? Kiwi10
