1Back to top Go down   Fuel pump replacement query Empty Fuel pump replacement query Wed Nov 20, 2013 9:18 pm
ianburgess
ianburgess
Hi
I have a dead fuel pump and a replacement is looking hard to get without spending a motza.
There is talk of using a Falcon fuel pump (EA EB ED EF etc) as a replacement but as they come with a hose fitting, I would need to cut the bottom out of the canister.
I talked to Repco and they said there are different pumps in sedans and wagons.
Anyone know which one I should be going for to try, or even if it likely to work?
Ian
K100RT 05/87 vin 0094099K100RT Dark Blue (ex cop bike)
2Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Wed Nov 20, 2013 9:39 pm
The one I use is an EB sedan and you need some fuel proof foam to wrap it so it fits the rubber damper and 2 big zip ties to hold it. It has a different prefilter on the base but if you fold it in half and put a wire tie to hold it that way then it goes in easily
This is the guy I bought mine from
http://www.ebay.com.au/itm/Fuel-Pump-Ford-Falcon-EA-EB-ED-EF-EL-XF-XG-XH-LTD-NA-NC-/151128415938?pt=AU_Car_Parts_Accessories&hash=item232ff49ec2
I even bought a spare to make sure I never need to replace a pump again.
He is at Springfield Bris you could get it today and see us at Guyra tomorrow
Last edited by RicK G on Wed Nov 20, 2013 9:44 pm; edited 1 time in total (Reason for editing : More info)
3Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Wed Nov 20, 2013 9:54 pm
Not sure what things are like on the half of the earth that spins the wrong way but I can get an aftermarket unit for <$20 by searching Fleabay for "fuel pump 2042."  Worth a shot, eh?
4Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Wed Nov 20, 2013 10:04 pm
It does not spin the wrong way it's just upside down:D
5Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Thu Nov 21, 2013 7:20 pm
ianburgess
ianburgess
Thanks Guys
Looks like it's worth a try.
Unfortunately the bike decided to stop 100km from home so I either have to get a pump replacement to work or trailer it back home.
Ian
6Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Fri Nov 22, 2013 3:00 am
If you get stuck try a 1988 to 1992 corrolla ae20 intank fuel pump for the efi corrolla or the 1988 onwards camry which also ran a rail pressure of 38psi both come with an odd filter on the bottom but can be made to work they will require zippy ties to locate (the thick ones) about 200 to 300mm long, charlie99 used one from a corrolla I think he still has it in the tank, so grab a new one or grab one from the wreckers on the way out to your bike
7Back to top Go down   Fuel pump replacement query Empty DIY Fri Nov 22, 2013 8:10 am
Ajays
Ajays
Fuel pump replacement query Th_Kengine_gif
AJAYS
8Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Fri Nov 22, 2013 10:12 am
Ghost who rides
Ghost who rides
Good to hear from you Ajays but no the link didn't work for me.
9Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Sat Nov 23, 2013 3:26 am
Ajays
Ajays
I have edited the url so try again. if not, I give up.  [I did not write this, it is another's work.]
Roll on 2014 'cos 2013 has not been good for us.  Wife broke hip, I got gout so no booze. Guess I am slowing down now.
Last edited by Ajays on Sat Nov 23, 2013 3:31 am; edited 1 time in total (Reason for editing : make clear not my paper)
AJAYS
10Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Sat Nov 23, 2013 11:09 am
Ghost who rides
Ghost who rides
Thanks Alan all good now. A neat solution for the pump.
Regards to your wife, It must be hard with restricted mobility, hope she recovers .
Cheers Gordon
11Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Mon Nov 25, 2013 10:15 am
hi gordo
yep the ae 86 ('82-88) the ae92 (88-92 ) have suitable pumps
the filter at the bottom should be good for doing the filter ..;instead of the basket that is standard on the k ( I had removed mine ...but wish I kept it on as the fuel level that it can suck down to is just a little higher ) no matter really
same terminals in every respect
BUT draws less power than the ford and bosch models made for bigger displacement vehicles
the "goss" fuel pump replacement catalogue list the rolla at about 3-4 amps where as the ford is up to 7 amps , kinda figures with the capacity differences required for the different vehicle engine sizes .
so im figuring a little less current through that tank connector is a good thing
hope that helps
be well ajays , best thoughts from here ol mate
12Back to top Go down   Fuel pump replacement query Empty Re: Fuel pump replacement query Mon Nov 25, 2013 7:39 pm
Ajays wrote:I have edited the url so try again. if not, I give up.  [I did not write this, it is another's work.]
They say if old age it catching up walk faster. The problem with that is I need to run and I cant.
