rexst
rexst
Please help
I just thought of this, please tell me if this is a good way to do this or not
If the K100 members would be so kind in helping me, I want to start restoring/fixing the bike and as a newbie/novice I don't have all the knowledge to do this on my own
my idea, and from the help of the members is to start at a point and work my way from a back to front or top to bottom /whatever the right way is. (but to have a certain order)
 is to check/fix/replace/restore/ the specific part /item - I will take whatever picture requested that members of the Forum can decide/help/give me advice what needed to be done.....  (I hope this is a good idea)
(buying of ebay will most probably be a problem for me - don't have a credit card, and have no idea how ebay works ) here is SA is engineers, bike shops, and also part stores, this wont be a 2 week project, it will take time, obviously money (as i dont have won the lottery yet, saving every month as I can) and patience - yes I know this
obviously 1st without stripping the whole bike (go around the bike take pictures)
then as time progress to start going into more depth on more specific items (better detailed pics)
I have no idea where to start, or what to look at, however I do have mechanical skills, and I tend to fix more stuff than I breaking them Hi , this will be my build and restore/fixing attempt of my K100 '83  Icon_rendeer
generally if I get stuck , I think outside the box, and find ideas/ think of a way to fix the problem
please feel free to encourage/discourage/give advice/rate my skills/request pics/show me alternaitaves
please start a list (please feel free to copy and edit the list) of things I need to do, take pictures/ video's,
i started  2 weeks back with the k100,
1st problem i ran into was the fuel pump was stuffed, (the rubber went to goo)
replaced with a universal pump, with fuel hose as the rubber damper, and some cable ties
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130819
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130820
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130821
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130822
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130823
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130824
Hi , this will be my build and restore/fixing attempt of my K100 '83  20130826
rexst
rexst
timing cover is cracked and also between the block and sump, just above the engine number there is a oil leak
3Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty ...now the hard part Mon Nov 04, 2013 4:50 am
rexst
rexst
i filled her up with fuel and oil, had some trouble but now she purrrrrs
now i need source a timing cover, and some gaskets , please advice or help or donate Sad
as its not the most popular bike here in sa
rexst
rexst
You Have Selected: 06/1983 K589 K 100 83 (0501,0511) Europe
 Hi , this will be my build and restore/fixing attempt of my K100 '83  20130827
does this mean i have a very very old one :pale:
I would say yes to that it is the earliest number I have seen and was made before they were released for the general market.
Last edited by RicK G on Mon Nov 04, 2013 7:49 am; edited 1 time in total (Reason for editing : ytop)
MikeP
MikeP
rexst wrote:i filled her up with fuel and oil, had some trouble but now she purrrrrs
Timing covers come up on ebay from time to time. They're not in huge demand so go fairly cheaply. I once bought one for £3 on ebay. If I see another going cheap I'll let you know and if necessary I'll buy it and post it out to you.
Three-Bond (Drei-Bond) sealant is used as opposed to gaskets.
As your bike is such an early example, I'd be tempted to get it back to as original as possible.
1992 K1
Brad-Man
Brad-Man
Looks like it has the later battery covers, seat and rear cowl on it - looks good!
the.postman
And a novel exhaust mod
1984 srx 600
1986 cbr1000f/h
9Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty .... Tue Nov 05, 2013 2:48 am
rexst
rexst
Brad-Man wrote:Looks like it has the later battery covers, seat and rear cowl on it - looks good!
, I have no idea
can you guys please post pics what it should have looked like, as im no expert , I really would like to restore it 100% , I really appreciate your guys opinions, advice and guidence
rexst
rexst
the.postman wrote:And a novel exhaust mod
hi post man, what is a novel exhaust mod, must I take it off and chuck it away, replace it?
how do I make this back original?
11Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty Some help please Tue Nov 05, 2013 3:39 am
rexst
rexst
edited moved right to the top (think it makes more sence)
the.postman
Your system
Hi , this will be my build and restore/fixing attempt of my K100 '83  Exhaus10
As far as I am aware all others are like this
Hi , this will be my build and restore/fixing attempt of my K100 '83  Exhaus11
Looks like the end piece has been removed
1984 srx 600
1986 cbr1000f/h
MikeP
MikeP
rexst wrote:can you guys please post pics what it should have looked like, as im no expert , I really would like to restore it 100% , I really appreciate your guys opinions, advice and guidence
If originality is your goal, you have some work ahead.
The front wheel is wrong, so too are the mirrors and front indicators. If the bike was a naked 'C' model (which I would expect given how early the VIN suggests), the handlebars need to be changed back to 'C' version.
As pointed out, the seat and tail unit are from a later bike and the silencer has been cut.
Then there's the colour of the wheels, they should be plain silver.
What you need to work out is whether it's worth it financially set against the desire to own a very early bike in as near original spec as possible.
1992 K1
rexst
rexst
ok maybe I haven't thought it trough as you mentioned it can become an expensive exercise  Sad
time is also an issue, we all have our day jobs, so weekends will be the time and place i will be working on the bike
I think that the main goal it to take what I have, and 1st repair/fix/replace/ask/beg/steal what is broken/   what needs to be looked at and fix that :-c: , get it mechanically sound Hi , this will be my build and restore/fixing attempt of my K100 '83  259495 , and get it presentable (make it pretty) again Hi , this will be my build and restore/fixing attempt of my K100 '83  292303
maybe the above is a better way to start off? please don't discourage me too much, i understand that i need to hear this as well, but at the end of the day , i think if i do a little each time with your /k100 members help, i will find success at the end of the day and will start seeing progress.?
I think that is the right way to approach the job and over the next year or so gather up the needed parts and maybe get it back to original.
BTW if you want a cam chain cover I can give you one but postage is up to you to pay.
PM me any details and we can organize things.
This is a side on of an RT but side covers and rear tail section and seat give you an idea of the seat etc that is right for your bike.
Hi , this will be my build and restore/fixing attempt of my K100 '83  Early_10
rexst
rexst
RicK G wrote:I think that is the right way to approach the job and over the next year or so gather up the needed parts and maybe get it back to original.
Hi Rick
thank you this is a very generous offer
I would love to have this part, how ever if it is the correct part (im not to sure if there is different models), I wouldn't want to take it if it does not fit my k100, do you want me to mail you pics/engine number?
I'm also not sure what the shipping to south Africa will cost, can you please find out for me? then we can take it from there
thank you once again for your generous offer
Hi rexst,
Here's a picture from the September '83 issue of Motorrad.
 Hi , this will be my build and restore/fixing attempt of my K100 '83  Sam_0513
Good luck with your new K,
Click here to download the 1983 BMW advertisement brochure.
All kind of pictures (naked, rt, rs)
CF
Hi , this will be my build and restore/fixing attempt of my K100 '83  Frog15Hi , this will be my build and restore/fixing attempt of my K100 '83  Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
MikeP
MikeP
I never noticed before, that the lower section of the tail unit was colour coded on the early 'C' models.
1992 K1
Good spot, Mike, I'd never noticed either!
club_c
club_c
Hi rexst,
Having refurbished/restored a couple of K bikes, and several other motorcycles, I always weigh the cost vs resale.  Here's the thing:  You would put a lot of money into a full resto back to original, especially since parts are difficult for you to source.  At the end of the day, when it comes to selling the bike, a prospective buyer won't pay you much more for a fully restored bike than a nicely tidied up slightly modified machine.
I would agree with your plan to get it running and not leaking, and pick away at the bad bits as time and money permits.  Frankly I like the newer tail, battery covers and seat better than the originals.  Reseal the cracked timing chain cover.  Remove those awesome Rolling Eyes  decals from the tank and covers, and try some paint stripper sparingly on the wheels to remove the red paint (do you have Q-Tips in SA?), and polish the stainless muffler.  This will cost you almost nothing, and will improve the cosmetic appearance a lot. You still move the project ahead without wasting any money or making non reversible mods.  (I suspect what you really want to do is RIDE?)
+1 on Tri-Bond...
After fixing the oil leaks, the next thing I would spend money on would be correct handlebars and then start looking for a correct front wheel.  That one looks a lot like an R series.  I would suspect you should be able to sell that for the same amount you pay for a K wheel, so that could be cost neutral.
There are a couple of SA K100 owners on this site, they may be able to help you access your parts.
If you are going to have to order parts from somewhere, you may want to set up a Paypal account to pay for items.  Simple to do, but I have no clue if it is supported in SA?
Cheers,
clubbie
1988 K100RS SE VIN 01477554
The front wheel and discs are from a Suzuki of around the same vintage.
Looking at the damage to the cam chain cover I would say it has been involved in a front on smash and a replacement front wheel was not available.
24Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty thanks for the feed back Tue Nov 12, 2013 1:57 am
rexst
rexst
This weekend I didn't got around to do much, visited my dad and mom, and I think my dad is getting more exited with my project Very Happy
the.postman
RicK G wrote:The front wheel and discs are from a Suzuki of around the same vintage.
Eagle eyed Rick
You'd do well in the spot the difference comp.
Same wheels as my old GSX 750ET used to have
Different forks?
Hi , this will be my build and restore/fixing attempt of my K100 '83  Suzuki10
1984 srx 600
1986 cbr1000f/h
26Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty some updates Fri Dec 06, 2013 2:40 am
rexst
rexst
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131110
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131111
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131112
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131113
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131114
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131115
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131116
rexst
rexst
im replacing majority of the screw's with stainless steel cap screws
now if only someone who is traveling from AUS to ZA to bring me a timing cover from Rick.........
..... hint hint
oooh red frame ......nice change !
good luck with the build ...post more pics as you go ...we love seeing this stuff
cheers !
rawdonball
rawdonball
I am flying out from Perth on Wednesday night 11th December.
Don't mind taking a timing cover off my K75C if Rick G can confirm they are the same as on the early K100?
As far as I can see the only difference is they are either black or silver and thats it.
rawdonball
rawdonball
Cheers Rick G. Can you give me an indication of the weight off your spare cover (assuming you have it available as an item and not still part of an assembly?)
rexst - can I leave it at a Mate's place near Randburg for you so you can liaise with him and collect when convenient for both parties?
rawdonball wrote: Can you give me an indication of the weight off your spare cover
2.13 lb, according to MaxBmw.
rawdonball wrote:I am flying out from Perth on Wednesday night 11th December.
http://www.realoem.com/bmw/partxref.do?part=11141460273
Yep just a touch under 1 kilo
rawdonball
rawdonball
Thanks Guys.
36Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty wow , this is so great of you all Mon Dec 09, 2013 1:01 am
rexst
rexst
thank you rawdonball and rick
I really appreaciate the efford you guys are doing for me
rawdonball randburg is fine with me, I will pm you my number and my mail adress
sometimes the generosity of the forum members amazes me
great work guys  applause from afar cheers Hi , this will be my build and restore/fixing attempt of my K100 '83  112350
38Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty some updates Thu Jan 09, 2014 4:13 am
rexst
rexst
first of all I need to thank Rawdon
he came all the way from other side of the world and brought along a timing chain cover for my bike
and did not ask me a cent
thank you I really appreciate your afford and It was really nice to have met you
39Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty update Thu Jan 09, 2014 4:22 am
rexst
rexst
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131210
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131211
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131212
40Back to top Go down   Hi , this will be my build and restore/fixing attempt of my K100 '83  Empty more Thu Jan 09, 2014 4:24 am
rexst
rexst
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131214
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131215
Hi , this will be my build and restore/fixing attempt of my K100 '83  20131216
Jez
Jez
Hats off to you rexst! from one newbie to another. It's daunting at first I know, I didn't wanna remove  anything from my K at first, but I'm now a little more comfortable being up to my elbows in K.
I'm lovin' your commitment, I'd love to get down to the frame myself and paint/ clean and seal everything that I put back on. Unfortunately I'm trying to get mine to reliable commuter state first. After that maybe K number 2 can be got. I reckon i'm not alone here in thinking a second bike is a GREAT idea. Ride one work on one. bounce
Wonder if I can get the Missus to see it the same way.
Keep up the good work,
Oh and a "Big Ups" again to the K100 forum you guys rock!
Jez.
84 K100 RS
Chassis number     0080546
