1 flashers fixed, but horns and fan... ? Mon Oct 28, 2013 1:15 pm
snowbeard
so I have rigged up some awful chrome signals to keep 'er legal without the fairing. I inserted the original fixtures and bulbs into the housings, cleanly as far as I could tell. Everything worked great, both signals working, etc.
then I had to charge the battery so I disconnected it so as not to fry the electrics. I also cleaned up the throttle gears, and so had to remove the switch housing on the right side.
now neither signal does anything, I don't hear any relays, nothing. Also the horns are out. I tried replacing the #3 down 15 amp fuse with no help. Any suggestions? I don't have an extra flasher relay to swap out, so I'd like to try other things first...
I guess opening up the housings and making sure nothing has shorted out is a good step, replacing all the fuses may help, but any obvious known issues would be appreciated!!
Thanks!!
Thanks!!
Last edited by snowbeard on Tue Oct 29, 2013 2:14 pm; edited 1 time in total (Reason for editing : the post has become more about the horns and fans once the flashers worked :-))
