1 Refitting footrests to footpeg plate. Advice needed as I'm struggling Fri Oct 18, 2013 12:32 am
I'm refitting the driver and passenger footrests to their respective plates but I'm struggling to get this done. Is there a trick to getting the parts lined up and the pin inserted? The process I've been working with so far is to have inserted the pin through the rest and then attempt to fit the tension spring, spool and plastic spring end afterwards. I can't get the spring to seat in the hole provided for it on the footrest. There has to be a better way to get this done. Any advice is gratefully accepted. I want to avoid scratching up my footpeg plates at all costs since they are freshly painted.
