1Back to top Go down   Temp Sensor Question Empty Temp Sensor Question Mon Oct 07, 2013 1:13 pm
klamityboy
klamityboy
I recently ordered parts (gaskets, coolant overflow hose, thermostatic valve and temp sensor) in anticipation of changing the coolant and refreshing the rubber bits. When I ordered the part, I specified the make and model of my bike (1991 K75RT-P). Upon receiving the parts, everything seem as I expected however it was clear that the temp sensor was different. See attached pic below. Item A is the temp sensor from the bike, Item B is the temp sensor I was sent. Can anyone help me with the correct part number to replace item A. Thanks
Temp Sensor Question Temp_s11
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
2Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Mon Oct 07, 2013 1:37 pm
Avenger GT
Avenger GT
Sensor A is the one for the temperature gauge. Sensor B is the one that tells the brain what temperature the engine is at, and also controls the fan. This is located in the vertical pipe at the back of the radiator.
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=GA&SbCt=BA_15_40_GA_60
Last edited by Avenger GT on Mon Oct 07, 2013 1:41 pm; edited 1 time in total (Reason for editing : Adding sensor B location.)
3Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Mon Oct 07, 2013 3:53 pm
klamityboy
klamityboy
Thanks. I asked for a temp sensor and didn't realize there were two sensors. I guess I will order the temp gauge sensor now.
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
4Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 12:58 pm
klamityboy
klamityboy
One more question. There was no crush washer on the temp gauge sensor when removed to drain the coolant. I reinstalled and replaced the coolant but there is a nagging doubt that there should be a crush washer. Thoughts?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
5Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 1:26 pm
No crush washer, the temp gauge sensor got conical threads.
6Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 1:38 pm
the.postman
Inge K. wrote:No crush washer, the temp gauge sensor got conical threads.
? So if you are replacing the standard plug with a sensor you dump the washer ?
1984 srx 600
1986 cbr1000f/h
7Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 1:45 pm
The standard plug got straight threads, so a crush washer is needed.
8Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 2:10 pm
the.postman
1984 srx 600
1986 cbr1000f/h
9Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 3:10 pm
klamityboy
klamityboy
I am not sure what you mean by conical threads?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
10Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 3:33 pm
the.postman
Conical/Tapered vs. Parallel Threads:
Temp Sensor Question Parallelvstapered
1984 srx 600
1986 cbr1000f/h
11Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Tue Oct 08, 2013 5:09 pm
klamityboy
klamityboy
I guess the taper is very slight as I did not notice a conical shape on the temp gauge sensor. Good news that a crush washer is not required as I would have had to drain the coolant again to put one on.Very Happy
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
12Back to top Go down   Temp Sensor Question Empty Re: Temp Sensor Question Thu Oct 10, 2013 1:09 am
brickrider
brickrider
I fell into this same screw-up.  I have a collection of parts I ordered over the years, then learned I had the wrong one or simply didn't need it (them) at all. Rolling Eyes
