1Back to top Go down   Missing fairing bolt Empty Missing fairing bolt Wed Oct 02, 2013 6:06 pm
BooG
BooG
Hi. I noticed whilst i was working on the bike that the fairing bolt which holds both side panels together under the head light is missing. Any one happen to know the size and gauge of the Allen bolt in question? Bike is an '88 K75S.
Ta!
2Back to top Go down   Missing fairing bolt Empty Re: Missing fairing bolt Wed Oct 02, 2013 6:37 pm
Check here;
http://www.realoem.com/bmw/showparts.do?model=0563&mospid=51744&btnr=46_0154&hg=46&fg=63&lang=en
If you put your VINnumber in "Serial number" , you will find exact your bike Idea
3Back to top Go down   Missing fairing bolt Empty Re: Missing fairing bolt Wed Oct 02, 2013 6:42 pm
MikeP
MikeP
It's M5x20. It's actually a cross-head screw and there should be a plastic collar through which it passes into an M5 spring clip.
Numbers 17, 18 & 19 here:
Missing fairing bolt B0001064
1992 K1
4Back to top Go down   Missing fairing bolt Empty Missing fairing bolt Wed Oct 02, 2013 6:44 pm
Or in my case a cable tie!!!
5Back to top Go down   Missing fairing bolt Empty Re: Missing fairing bolt Thu Oct 03, 2013 5:00 am
I just ordered the same pieces yesterday from the dealer.  Not all thaaaat expensive.  You could probably get second hand ones from Motorworks if you are on a budget.
