1Back to top Go down   Brake Disk Runout  Empty Brake Disk Runout Thu Oct 03, 2013 4:09 am
I got a RWC/Rego on the blue bike today. This was the first time I've ridden it any distance after pulling it to bits and I notice a plulsing from the front brakes when they are heavily applied. A friend of mine runs the workshop at Springwood Suzuki and he did the Road Worthy Certificate for me. He also noticed it and told me it's runout on the disks. He measured the run out and said it's within spec but half way to being out of spec. I did a lap over Mt Cotton and back up the Freeway and it's manageable but very annoying.
Apart from swapping the disks, is there anyway to remove the run out problem. Both front disks are 4.64mm and the service limit is 4.5mm so there's not a lot of spare meat on them. I searched for this and read a thread where someone used an oil stone on a rear disk to flatten it by running the engine, in gear and grinding the disk with the stone. I'm wondering if that's a can do for the front somehow as well? Obviously I don't want to spend another razoo on this bike Smile
Any ideas?
2Back to top Go down   Brake Disk Runout  Empty Re: Brake Disk Runout Thu Oct 03, 2013 4:20 am
To be quite honest I would seriously doubt a story like that.
I used to reco discs at one place and that sounds like a fairy story.
Find out which one is bad and replace it because to take enough of a disc to get rid of a pulsation like you describe would take it way under spec.
You may even be able to get rid of a lot of the pulsation by turning one of the discs 180° on the wheel, it could compensate for the other if both are out a bit and in the same place. Its worth a try and you dont even have to remove the wheel.
3Back to top Go down   Brake Disk Runout  Empty Re: Brake Disk Runout Thu Oct 03, 2013 4:29 am
The floating discs (I have them too) seem to be very thing and easily bent. I would suspect that a PO had been a bit rough with them when removing the callipers to take the front wheel off at some stage. At that measurement do what I did and order a new set of EBC discs online direct from EBC UK.
4Back to top Go down   Brake Disk Runout  Empty Re: Brake Disk Runout Thu Oct 03, 2013 4:37 am
It was CF. I re read it and he ground a grooved K1100 disk for a K100 bike.
He told me this morning both disks showed run out and I think he said they measured .08 and spec is .2  I'll try rotating one disk to see what happens. If I have to I can put the used disks off the RT onto this RS and buy new disks for the RT. Cheers.
5Back to top Go down   Brake Disk Runout  Empty Re: Brake Disk Runout Thu Oct 03, 2013 4:59 am
To grind back thickness maybe but you would need to be lucky to get a run out or a high spot out
6Back to top Go down   Brake Disk Runout  Empty Re: Brake Disk Runout Thu Oct 03, 2013 5:17 am
Cheers Bikerboy, I think you got it in one. The PO has twisted the disks.
I slipped out to the garage while there was a bit of daylight left and rotated one disk 180 degrees. It hasn't fixed it but that change improved it a lot. I'll see if I can get away with it like that for the sale.
A couple of pair of brake pad mounts with oil stones instead of pads would do the job Smile
Even if they are wafer thin, doesn't that just mean you need more brake fluid Twisted Evil
