1 86 K100 Starter Motor trying to start bike no ignition on Thu Jul 22, 2010 5:41 am
Agent
Hi I am the new kid on the block, I have a 1986 K100RT which I have owned for about 5 years, the other day I went and had fitted 2 new tyres, I left the tyre joint and when I came to the first corner that I needed to indicate around when I did this the indicators both flashed once and the was that. I had this problem before a couple of years ago and was advised that it was the brushes in the starter motor...these were replaced and the problem was fixed. This time however when I got home and parked the bike and turned the kill switch off the starter motor tryed to start the bike up again, so I turned the key off, still the starter kept running. I ended up having to undo the battery cable before I burnt out the starter. I have removed the starter and checked the brushes...all ok, checked that the relay points are not welded..all ok, so I am now at the point of where do I go from here, does any one have the next step I need to take?
Kindest Regards Agent Mulder
