2 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 5:14 am
MikeP
Nice, neat job. The only thing I'd have done differently is to use copper nuts on the header studs (much easier to deal with later).
1992 K1
3 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 5:17 am
looks great timber ,,,,,well done !
4 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 6:00 am
"Nice, neat job. The only thing I'd have done differently is to use copper nuts on the header studs (much easier to deal with later)."
Best thing to use is all Titanium nuts and bolts. I used to get hold of loads from the Tornado aircraft in my last job and they are never affected by heat or corrosion.
5 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 9:11 am
MikeP
I wish that you'd owned this K1100 at some stage then. Despite plenty of heat and soaking the second nut I've tried has just sheared the stud.bikerboy wrote:Best thing to use is all Titanium nuts and bolts. I used to get hold of loads from the Tornado aircraft in my last job and they are never affected by heat or corrosion.
1992 K1
6 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 9:28 am
Ghost who rides
Good pics especially the last one, don't see that view normally.
Correct me if i'm wrong but brass was the NUT of choice ?
My old 1952 International truck, no history, was the GO!
Fine thread, steel nuts. I am the biggest Slammer of American tech, bar none, call me a convert!
IF, IF, you want the best, custom your exh studs, fine thread for the pipes, with neverseize etc.
never be a problem again IMHO.
1986 K 75 C 2nd owner 187,000kms showing .
1987 K100RT Police repainted, rough and unloved.
7 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 12:21 pm
Nice timber, Can you do mine next please
88....May contain nuts!
K75RTP - 1994
8 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 6:13 pm
klamityboy
Very Nice. What did you use to polish the exhaust?
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
9 Re: Welded exhaust, cleaned it and cleaned the headers Tue Oct 01, 2013 7:23 pm
Yes Bikerboy, I still have the screw you gave me last summer..... Light, strong and expensivebikerboy wrote:"Nice, neat job. The only thing I'd have done differently is to use copper nuts on the header studs (much easier to deal with later)."
As Ghost who rides stated, neverseez is the best and cheaper treatment that you can give to you exhaust nuts and studs. I used it in a lot in marine environment where salty water and heat are corroding any screws.
CF
1986 k75, 1985 K100rt, |
10 Re: Welded exhaust, cleaned it and cleaned the headers Wed Oct 02, 2013 12:23 pm
Shep
Please clarify which Never Seez product should be used on the exhaust system?
Shep
Shep
Model Production Date/Serial Number
K100RS 1984 July/ (F0040448)
K100RS 1986 Dec/ (H0142581)
11 Re: Welded exhaust, cleaned it and cleaned the headers Wed Oct 02, 2013 1:59 pm
the.postman
The Nickel anti seize is there product
Protects metal parts from seizing and galling at temperatures of to 2400°F (1316°C). Copper-free, use under conditions of extreme pressure and temperature and with stainless steel, titanium and nickel alloys.
Or a copper slip with similar temp properties will help
1985 K100 RS 104EA49840092 #0081788 SILVERish (Madison) Prod. date 05/12/84
1984 srx 600
1986 cbr1000f/h
12 Re: Welded exhaust, cleaned it and cleaned the headers Wed Oct 02, 2013 3:07 pm
k-rider
nice job, you must have cleaned the cylinder head too ?,did you use a wire brush and autosol for the headers?
k100rs 1983 -o:
Shinny black ,exaust from a 16valve ,engine from a 1990 K100 lt,fd ratio :32/11
13 Re: Welded exhaust, cleaned it and cleaned the headers Sun Oct 06, 2013 6:12 am
Timber
I used a wire brush on the headers and diesel and a toothbrush to clean the rest before re-installment.
Similar topics
