1 suggestions on removing scratches from system cases Mon Sep 02, 2013 10:30 am
wildwestrider
I have OE System cases on my recently acquired 87 K75. One of the System case lids has some light scratches on it from a driveway drop by the Prior owner.
The finish on these system case lids is much smoother than on my prior Oilhead and K1200 bikes,.....thinking that they might clean up with some wet sanding,....but thought I should check here first to see if this has been tried or if there is a tried and true method for cleaning up these case lids.
Brian in Austin
Brian in Austin
