1Back to top Go down   K75 silencer gasket Empty K75 silencer gasket Mon Sep 09, 2013 7:00 pm
JGT
JGT
The K75 uses a composite gasket joining silencer to exhaust pipes. What is its purpose and is there a suitable alternative to this rather expensive one use item? The K100 being designed without the need for this joint. John
2Back to top Go down   K75 silencer gasket Empty Re: K75 silencer gasket Mon Sep 09, 2013 9:14 pm
MikeP
MikeP
I've used exhaust joint compound, not to be confused with exhaust repair paste (such as GunGum).
However, it's never been quite as successful as the gasket.
3Back to top Go down   K75 silencer gasket Empty Re: K75 silencer gasket Tue Sep 10, 2013 2:08 am
I only bought one of those things and ended up making a sleeve from a piece of 0.42 colourbond steel sheet, got it to seal quite well and it doesnt fall to bits every time I remove the muffler.
