sandman jim
hi..just balanced my front wheel at home new avon roadrider 100/90/18 on my k100rs took 45 grams,,,how does this compare with your bike any comparisions wuold be great....regards jim how many grams to balance your front wheel Icon_smile
Hi Jim,
My front has 10 and 5 = 15 grammes on each side, so a total of 30 grammes. The really keen guys with home wheel changing gear start with positioning the dot relative to the valve and then try moving the tyre round the rim back and forth till it is best and only then put weights on to balance the last bit. I assume you are using a purpose made balancer not using the wheel bearings?
