1Back to top Go down   FORK OIL COLOUR Empty FORK OIL COLOUR Fri Jan 13, 2012 4:44 am
Lazyboy
Lazyboy
I have just finished draining my fork oil and found that the left fork oil looks almost new, but the right forks oil has come out looking a Dark Grey colour ! What could be the cause ? Should I be concerned ? I did not feel any handling problems and was just going the anual fork oil change.
Thanks, Ronnie.
2Back to top Go down   FORK OIL COLOUR Empty Re: FORK OIL COLOUR Fri Jan 13, 2012 5:06 am
both mine were kinda dark ronnie ...after a year of oil and travells ...maybe i need to flush as well before putting the new oil in ?
3Back to top Go down   FORK OIL COLOUR Empty Re: FORK OIL COLOUR Fri Jan 13, 2012 5:47 am
Toto_jp
Was it a metallic grey or had metal flakes ? if so indicates some wear inside or if its milky grey could indicate moisture maybe has been flushed with a water based cleaner and was refilled before thoroughly dry
K100 RS 1986
4Back to top Go down   FORK OIL COLOUR Empty Re: FORK OIL COLOUR Fri Jan 13, 2012 5:52 am
Change both and see how it goes Ronnie. Water would be my first suspect.
5Back to top Go down   FORK OIL COLOUR Empty Re: FORK OIL COLOUR Fri Jan 13, 2012 1:22 pm
Lazyboy
Lazyboy
Thanks All for the advice. found no metal shavings, more a milky grey .I think you are correct it could have been water. Will keep an eye on it.
1984 BMW K100RT
Bikes Name: Lazyboy
