1Back to top Go down   New horse in the Stable. Empty New horse in the Stable. Fri Sep 13, 2013 8:19 pm
A week tucked up in bed with a chest infection and a laptop can be a dangerous thing!
Well as a result and as the title says. I've acquired a new moto. I've had a itch for a naked K that needed to be scratched for some time and after watched  (a very few) ads for k75c's over time come and go. I happened to be online last week and looking at Gumtree as the add went up for one in my budget.
Last night, after work I took a trailer to Dungannon in Northern Ireland to look at the bike and brought it home. It's a 1991 metallic black with some very light cosmetic damage and a few bodge jobs done on it it was dropped at low speed on a gravel road and the damage tallies with the sellers description. the radiator cover has a shorn studon the right side. The headlamp surrounf is dented. The plastics back of the clocks and base of the front indicator are grazed and the headlamp glass was replaced with a left hand drive one. The heat shield was painted with something which doesn't like heat and the front of the seat was repaired with staples which have scratched the tank. The front mudguard is  bent and has cracked paint.
All that said,  the bike, once started, runs very sweetly gearbox and brakes are all good. Valve stem seals have been done but the steering head bearing feels like it has been over tightened just a pinch. The bike doesn't always start so I reckon the starter needs an overhaul to improve the contacts and earth. It's going to make a nice project bounce
Hello little cousin....
New horse in the Stable. Img_1410
New horse in the Stable. Img_1411
Exhaust shield will clean up easily
New horse in the Stable. Img_1412
some "Gifted" individual came up with this method of securing the panniers....
New horse in the Stable. Img_1413
it might take a while to get going on it as the LT needs the oilwater pump seals done,  a timing chain and a spline lube first.
New horse in the Stable. Ir-log1188....May contain nuts!New horse in the Stable. Ir-log11
K75RTP - 1994
2Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Fri Sep 13, 2013 8:37 pm
Awwww. Isn't it cute sitting there.
Well done.
Exactly how every garage or shed should look.
One on the left and one on the right.
3Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Fri Sep 13, 2013 9:39 pm
wow !
will, what a score .....im very jealous out here
onya mate
4Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Fri Sep 13, 2013 10:19 pm
charlie99 wrote:wow !
onya mate
Cherers Charlie - You would be twice as jealous if you knew what I paid...but I'm still not the bandit Comberjohn is Smile
K75RTP - 1994
5Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Fri Sep 13, 2013 10:45 pm
blast  another  pirate huh ? .....oh well ill keep looking
6Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 3:12 am
MikeP
MikeP
Well done that man!
The heat shield will probably look like Swiss cheese once you get the paint off. The black ones used to be dirt cheap (14 quid from Motobins) but they've realised the demand and hiked the price hugely.
There's a K75 radiator surround on ebay at the moment.
1992 K1
7Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 3:52 am
k-rider
k-rider
nice one , she will make a nice project for the Winter, are you going take it completely apart  , for an overhaul, or "just" a touch up Very Happy i heard somewhere that the k75 engine runs smoother than the k100 , what do you think?
8Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 4:28 am
jjefferies
jjefferies
You mentioned
the radiator cover has a shorn stud on the right side
If it's not lost or badly mangled you can relatively easily repair it. Two options I've used:
1. epoxy filler to fill the gap between the stud and the cover.
2. PVC glue worked another time to glue a partially torn off piece.
PVC glue ( stuff they use to weld together PVC pipes for electrical conduit and other uses) is also useful for the bag outsides. Possibly fix the fix they did for latches.
9Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 5:49 am
MikeP
MikeP
k-rider wrote: i heard somewhere that the k75 engine runs smoother than the k100 , what do you think?
The K75 engine is smoother. The output shaft is counter-balanced. The four cylinder engine can be smoothed out by ensuring that the valves and injectors are correctly adjusted but it will never get near the three cylinder engine for smoothness (which just gets smoother the faster it revs).
1992 K1
10Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 6:03 am
BIG D
BIG D
Cool
Great find 88 a companian for the LT,
a single bike can get lonely, that was my excuse to the wife Very Happy
you now have plenty to keep you going over the winter good luck with her mate.
BIG D
11Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 6:30 am
Yep....Waaay Smoother than the k100! Thanks re the shield MikeP Looks solid though thankfully.
@JJeffries - Thanks - stud is gone Might get something machined up in aluminium to replace it, as for the pannier "improvements".....Well New horse in the Stable. 652573
K75RTP - 1994
12Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 9:31 am
JGT
JGT
Interesting comment that you think the steering head is too tight. I have been running a K75 now for about six weeks and still haven't come to terms with the steering which feels stiff and I assume is caused by stickiness in the fluidbloc damper. Are they meant to be like this? Its not a problem just makes the steering slow. John
13Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 9:38 am
If the triple tee has never been removed, the grease is certainly dry and this is what makes the steering stiff. I remember when I bought my K100, I had the same problem. I temporary solved it by spraying the bearings with WD40.
New horse in the Stable. Frog15New horse in the Stable. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
14Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 10:51 am
MikeP
MikeP
BMW no longer supply the "special" grease for the Fluidbloc. A replacement is about 20 quid and comes with loads of the stuff slathered liberally inside it.
It's been upgraded too. The early ones relied on the grub screws to penetrate the nylon cylinder to hold it in place. When the grease began to dry out the damper could stick to the steering stem and the screws cut grooves in the nylon allowing the damper to rotate with the steering and not do its job.
The later version now has an aluminium outer sleeve. The grub screws still just poke holes in the thing to hold it in place but it won't fail like the old version.
Old (with two cuts when the damper stuck to the steering stem):
New horse in the Stable. K75S%20%2841%29
New and old for comparison (the new one still has the grease retaining sleeve inside before fitting):
New horse in the Stable. K75S%20%2875%29-L
The bike was fine at any speed and in a straight line with the failed damper but on high speed bends it just wouldn't keep to the desired line and it was impossible to predict what line it would take.
It's definitely worth investigating if you have a K75 (not RT, they didn't have the damper) and the steering is not right.
1992 K1
15Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 2:29 pm
JGT
JGT
Very interesting. Will have to wait until the weather changes before I investigate. I plan to strip the front end, fit new fork seals and gaiters. The bike has done 87,000 miles so there is a good chance the fluidbloc is u/s. John
16Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 2:45 pm
brickrider
brickrider
Nice find, 88. Congratulations.
I see that being in bed with an illness can have its upsides! Very Happy
The plastic fairing bits can be repaired with PVC glue/solvent?  Is that true of the K100 (1985 vintage) bikes as well?  I've got a broken tab on the side panel of the fairing that I'd like to attend to.
17Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sat Sep 14, 2013 6:31 pm
Thanks for the tips re the fluidblock, that's definitely one of the first things to check. The steering is fine when leaning in but any other input such as little pressure on the bars then the movement seems twitchy and sometimes quick and slightly more than was asked for. This feeling of resistance then marginal over response would be explained by the fluidblock being worn and with old grease.
K75RTP - 1994
18Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 7:10 am
Comberjohn
Comberjohn
Missed you yesterday, Will.
Boy, you've got it bad. How much did he pay you to take it away?New horse in the Stable. Icon_razz
Thinking of doing something similar over the winter. Liked the K without the fairing. Totally different bike, but keeping it on my RT in the meantime. Everytime I take it off the temperature drops!
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
19Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 7:36 am
Comberjohn wrote: Liked the K without the fairing. Totally different bike, but keeping it on my RT in the meantime. Everytime I take it off the temperature drops!
John I totally agree. I got a bit chilly today on the /2. Temp dropped to 15c
I can see the advantage of the RT fairing, but riding without it is so much better.
Have you considered a smaller fairing? easy on and off? or just leave it on
I saw a K75 today that had an aftermarket bikini fairing. Just enough to keep the wind off your body.
Guy said he had 3 screens depending on the weather.
this screen is the summer one.
New horse in the Stable. Dsc05110
20Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 8:38 am
Comberjohn
Comberjohn
15c! That's our summer!
When we started out on our run yesterday it was 9c. Warmed up to the high teens by late afternoon but was back down to about 10c in the evening when I left the guys at their hotel.
Doesn't normally get really cold here over the winter and we can generally ride all year round providing we have a fairing.
Think I need another naked K though for a bit of fun on shorter runs.
Was test riding a KTM 1190 Adventure on Friday. 150bhp and 200kg.
Now thats a naked! Scary. New horse in the Stable. Icon_twisted
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
21Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 10:57 am
Alheng
Alheng
Nice find! I'm still looking for a decent one!
22Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 11:20 am
I took the bike for a run down the hi way to the Gold Coast today to check fuel economy and was dying from the heat just 20Ks from home, behind the RT screen. Pulled into a bike shop and bought a modern jacket with air vents everywhere. I still love my 30 year old alpine dryrider jacket, but not behind a windscreen on an RT. I could get away with wearing a suit behind that thing.
I wish we had the selection of bikes available that you guys seem to have. I've never seen a cheap K75 4sale here.
The only ones I've seen are pristine and the owners think they are classic vintage bikes and priced accordingly.
23Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 6:06 pm
k-rider
k-rider
i have an rs , and that Works perfect all summer , but in early spring an in the autumn,not sure how that is spelled, Sad it might be as low as 5c , i use an aeroflow screen, it comes right on and of attached with velcro, and give real good protection against the weather:D
24Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Sun Sep 15, 2013 6:56 pm
Comberjohn wrote:Missed you yesterday, Will.
Exactly 1.5 times yours! not bad for a 91 runner I think!!
K75RTP - 1994
25Back to top Go down   New horse in the Stable. Empty Re: New horse in the Stable. Thu Sep 19, 2013 2:32 am
zonenfeile
zonenfeile
Nice picture of the fluid block !
in 2008 i changed the bearings and checked the fluid block in my K75/2
as always:
no function due the fact : no/dry grease after 18 years
i cleaned it and refilled the fluidblock with Liqui Moly 3312 Silicon grease
best results !
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
