1 Fork oil diagnosis Sat Aug 10, 2013 5:10 am
OZhoppo
I took the K100RS for a spin today (beautiful weather in Canberra for once) and found that the girl just does not seem to ride right.
When I picked the bike up I discovered the right hand fork had slid through the top triple by about 20mm. I fixed that and then checked all of the bearing, etc which all seemed OK.
Today on the ride the bike seemed to be very very harsh over mild ripples and had a mind of her own over seams in the tarmac. I stopped to check the Koni rear shock and set it back to 1 (of 4) damping settings. This seemed to settle things down a little but it was still harsher than I remember.
I bought her home and drained the fork oil. Right side (the one that had slid up) had 400ml of what looked like liquid titanium (almost silver in colour). The left drained 360ml or worn oil more black than clear.
I refilled the forks with 360ml of 10W oil and gave the front end a few bounces to settle everything before putting the carps back on.
I have to say that I am not sure that it made any difference. If I hold the front brake the forks compress a good 4-5 inches and rebound PDQ before settling down after one 'bounce'
I am a life long Ducati rider and the way the forks worked would worry me a lot... but is that normal for a 1991 K100RS ?
