1Back to top Go down   Clutch and throttle cables cleaning Empty Clutch and throttle cables cleaning Tue Oct 13, 2009 11:48 pm
elle
elle
Hi have read that you shouldnt use wd40 or similar as it will mess up the linings on cables.Ive just got a couple of cables (clutch and throttle to keep in rear cowl as spares just in case,so what would i use to keep them lubed? oil,thin oil?
Dont want to get to a point where i need them to find theyre siezed.
thanks for help
pete
Pete,
Yes, WD40 will destroy the lining.
You can keep them in a sealed vacuum plastic bag.
I personally don't think the cables will seize if they are not in direct contact with water.
I have one in my cowl for over 7 years, and it seems to be free.
Don't forget, if your clutch cable brake, the first thing that you will lose is the small nipple (part #10).
If you have a spare one, be sure that you tape it on the spare cable.
I have only one spare cable for 2 bikes, but if I had only 1 bike (or 2 spare cables), I would double my original cable (tape the spare one to the original.) This way, if you have to replace it on the side of the road, you wouldn't have to remove the tank install it.
Clutch and throttle cables cleaning Cables10
Clutch and throttle cables cleaning Frog15Clutch and throttle cables cleaning Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
